06-22-2015, 08:14 PM | #1 |
lightissues
Hi,
When I turn the cowl lights on the headlights are also on , both low and high beam. When I turn the headlights on,the cowl lights are also on.Any ideas as to what is going on and how to fix it? Thanks. |
06-22-2015, 08:45 PM | #2 |
Re: lightissues
Look for bad grounds at any of the bulbs. Remove one bulb at a time and test the lights again to see which bulb improves the situation.
Once all 4 of the bulbs are out, see if you continue to get voltage at all 3 places (high, low, park) no matter which position you put the light switch lever on the steering wheel. If you still have the problem, the wiring harness may be assembled incorrectly inside the light switch housing. Gently take it apart and look at how the switch inside the housing is contacting the brass buttons on the wiring harness. Look at how the spider is on the rod end and how it engages the switch.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" Last edited by Jim/TX/GA; 06-22-2015 at 11:28 PM. |
06-23-2015, 07:06 PM | #3 |
Re: lightissues
Thanks Jim. This is a great place to start. I was drawing complete blanks on this matter...no idea where to begin.
06-23-2015, 10:25 PM | #4 |
Re: lightissues
If you have a harness with 3 wires and contacts at the base of the headlamps, I would check the contacts. Some of the repro contacts are large and loose, and they touch each other. Since you have cowl lights the headlamps should only have two wires, but sometimes the wrong harness gets installed, or someone adds cowl lights without removing the headlamp parking lights.
06-24-2015, 07:26 PM | #5 |
Re: lightissues
