12-04-2019, 07:55 PM | #1 |
55 Ford Fairlane hinge pin
My driver door on my 55 is starting to drop, I'm pretty sure the hinge pin on the bottum hinge needs to be replaced. When I look in my parts catalog I can find a pin for a 55 but no bushings, before I pull the hinge I would like to have the parts to fix it. Anyone know if the 55 used bushings or just pins?
12-04-2019, 09:16 PM | #2 |
Re: 55 Ford Fairlane hinge pin
Maybe just the pins. Dearborn Classics shows bushings for for '55 Birds and F100 only. '57 is the earliest full size Ford they catalog the bushings for.
https://www.dearbornclassics.com/195...ro-torino.html
Often wrong but never in doubt. |
12-05-2019, 09:31 AM | #3 |
If they (bushings) are worn, you will most likely have to have then redone (add material and re-drill) and/or see if the bushings can be drilled OS to accept the later brass bushing. as the hinges are hard to come by.
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
