Old 02-19-2018, 12:17 PM   #1
Great Lakes Greg
Great Lakes Greg's Avatar
Default Your wheel painting technique
My powder coat guy is out of business and I find myself in the position where I am going to have to paint some wheels. I have access to a wheel spinner and may build my own as well. So, how do you get in behind the spoke at the hub end? Any other tips on painting wheels, and kindly describe your home built wheel spinners if you have one.
Great Lakes Greg is offline   Reply With Quote
Old 02-19-2018, 12:26 PM   #2
biggieou
Default Re: Your wheel painting technique
Where are you located? I just has my wheels powder coated and couldn't be happier with the results.
Sent from my SM-N920V using Tapatalk
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 02-19-2018, 01:09 PM   #3
Great Lakes Greg
I am in Jackson. There are other powder coat guys around, but their color chips are nowhere near Tacoma Cream. The place I used to go to had a stash of the right shade from the now defunct ModelAwheelcolors.com. A search on this site says Tiger RAL 1001 is a match, but it looks light brown to me. I would feel better just painting the right color.
Old 02-19-2018, 01:19 PM   #4
1931 flamingo
1931 flamingo's Avatar
Years ago (60's) three of us painted the wheels on my 32 4 door sedan with brushes in the back of the barracks. Red rustoleum on mounted wheels, oh yeah and at least a case of beer...........Came out good. One of the cars I wish I still had
Old 02-19-2018, 01:26 PM   #5
biggieou
Jackson, Ohio? My wheels are Tacoma Cream. Really happy with the results. I'll post a pic, but I don't think the pic does the true color justice. They look much more yellow in the pic then they are in person. I got the powder from modelawheelcolors.com
1950 Mercury 8
Old 02-19-2018, 02:15 PM   #6
wrndln
I have seen wheels slid onto a long pipe for painting. Then as the wheels are painted (both sides), you turn the wheels by only touching the place where the tires go. It looks like it would work well. I have 2 sets of 21" wheels that were powdercoated, but I am going to paint the next set. I plan to paint my wheel using the pipe method, even though our local club as a wheel rotator. The main problem with a rotator, like our club has in the tool loan program, is it only does one wheel at a time. With a long pipe, after painting a wheel, you can drag the painted wheel off to the side with a hook and paint more wheels on the pipe. The problem with powdercoating is most wheels have dings and flaws that need "filling". Supposedly J-B Weld is good to 500 to 600 degrees, but some of the J-B Weld sagged when the powdercoated wheels were baked, even though I told the powdercoater to cure them at the lowest possible temperature.
Rusty Nelson
Old 02-19-2018, 03:42 PM   #7
Afordman31
Afordman31's Avatar
This is the technique I used to paint my wheels. I got the information from the Restorer book shown in the picture, page 23.
The wheel spinner is made out of scraps of wood, a thrust bearing, and a 1/4 inch bolt.
So far this was used on 10 Model A wheels and 5 1935 Ford wheels for my speedster.
You will see in the picture that there is seven different positions to paint a wheel. The first day paint the part of the rim that the inner tube touches and the inside of the hub. The next day when the paint is dry you can set the wheel on the spinner and turn it by touching the part where the tube covers. Then do the sequence shown in the picture. There is seven different positions to spray a wheel. I also made metal plugs to drop in the holes so you won't paint where the wheel lugs touch.
Hope this puts some light on your post!
Afordman31 is offline   Reply With Quote
Old 02-19-2018, 06:39 PM   #8
Chris Haynes
Chris Haynes's Avatar
http://www.modelawheelcolors.com/
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-20-2018, 09:14 AM   #9
Hoogah
Hoogah's Avatar
Necessity is the mother of invention. I hesitate to post these photos because this is the most unprofessional get up imaginable, but this is how I sprayed my "new" spare wheel with a rattle can.
(. . . . ducks for cover!)
Hoogah is offline   Reply With Quote
Old 02-20-2018, 10:33 AM   #10
Keith True
Keith True's Avatar
The problem I always have with the idea of using a spinner is that I can only do one wheel at a time.I would have to guess,and mix up the DP 40 to shoot one wheel.Then do it all over four more times.Then for color go through the same thing again.I think that Restorer article was written when you could mix up some primer,use some,then put a piece of masking tape over the vent hole in the cup.Shake the cup the next day,pull the tape off and use it.Same thing with color.The last couple dozen wheels I painted I did on a long steel rod.I slide a half dozen wheels on a 20 foot piece of round bar stock and lay it between two stepladders.I spin them as needed with my finger.You do have to steer them as you spin,a one inch diameter bar will sag a lot with a few wheels on it.The little marring on the insides of the wheels from the bar seem to fill themselves in.
Old 02-20-2018, 12:05 PM   #11
Dick Steinkamp
Dick Steinkamp's Avatar
I am in Jackson.
Jackson, Alabama
Jackson, California
Jackson, Georgia
Jackson, Idaho
Jackson, Indiana
Jackson, Ripley County, Indiana
Jackson, Kentucky
Jackson, Louisiana
Jackson, Maine
Jackson, Michigan
Jackson, Minnesota
Jackson, Mississippi
Jackson, Missouri
Jackson, Nebraska
Jackson, New Hampshire
Jackson, Camden County, New Jersey
Jackson, New York
Jackson, North Carolina
Jackson, Ohio
Jackson Township, Susquehanna County, Pennsylvania
Jackson, Rhode Island
Jackson, South Carolina
Jackson, Tennessee
Jackson, Washington
Jackson, Wisconsin (disambiguation)
Jackson, Wyoming
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 02-20-2018, 01:44 PM   #12
TomballMottershaw
Missed... Jackson county Texas hehe.
TomballMottershaw is offline   Reply With Quote
Old 02-20-2018, 01:45 PM   #13
Afordman31
Afordman31's Avatar
Originally Posted by Dick Steinkamp View Post
Jackson, Alabama
Jackson, California
Jackson, Georgia
Jackson, Idaho
Jackson, Indiana
Jackson, Kentucky
Jackson, Louisiana
Jackson, Maine
Jackson, Michigan
Jackson, Minnesota
Jackson, Missouri
Jackson, Nebraska
Jackson, New York
Jackson, Ohio
Jackson, Tennessee
Jackson, Washington
Jackson, Wyoming
Easy to figure out, Great Lakes Greg
Old 02-20-2018, 02:00 PM   #14
jwilliams81
jwilliams81's Avatar
Originally Posted by Chris Haynes View Post
Have you bought from them or used them?
I tried to buy powder from them and they took my money and didn't send me product. I called for 2 months leaving messages and emails. I finally filed a complaint with Paypal to get a refund. Then filed a report with the state attorney general.
If you used them and had great results I'm glad. But I didn't and wouldn't steer people to the company. My 2 cents.
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 02-20-2018, 02:22 PM   #15
Dick Steinkamp
Good point.
We're down to...
Jackson, Wisconsin
Jackson, Minnesota
Jackson, Michigan
Jackson, Ohio
Jackson, Pennsylvania
Jackson, New York
Jackson, Indiana
Old 02-20-2018, 02:40 PM   #16
biggieou
I literally posted in here that I did. Great product.
1950 Mercury 8
Old 02-20-2018, 03:28 PM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Use the trigger handle on your spray can & the GOOD spray tips that makes a true FAN shaped spray!
In our REALLY POOR times, & poor wheels, Chief burned off the hard tires & the paint, on a bonfire. Then with a WIDE, CURLY old brush, I'd dab that old roofing tar from a silver, no label can, into the hidden areas, then "smooth" it out all over. Looked pretty good & didn't CHIP or RUST!
Bill W. (My spray can jobs looked as GOOD as POWDER COATING!)
"THE ASSISTANT GURU OF STUFF"
Old 02-22-2018, 07:38 PM   #18
Fred K-OR
Fred K-OR's Avatar
I did almost the same thing as you did. Works great. Here is a picture.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-22-2018, 10:46 PM   #19
Hunter
I concur with Rusty and Keith. I had borrowed a variable speed motor with a gear box and spend days building a contraction that would spin the wheels for me as I sprayed. What a total waste of time. I found that having them spin at a constant rate just didn't work for me.
So - I got a long piece of pipe and suspended it between two ladders like Keith. I spun the wheels by putting my fingers on the part of the wheel where the tire liners go. This worked well as I could go forwards, backwards, or just stop rotating them and take a look before proceeding.
It seems like painting wheels would be very difficult, but once you do one or two wheels you will wonder why you were worried about painting them.
Hunter
Hunter is offline   Reply With Quote
Old 02-23-2018, 06:45 AM   #20
3.6rs
3.6rs's Avatar
Simple, cheap and quick set up, but very effective !
3.6rs is offline   Reply With Quote
