10-08-2018, 11:06 PM | #1 |
Diff leaking around the bolts
We've just returned from our National Model A rally. Over 1500 miles and the car didn't miss a beat. Averaging about 80 kph (50 mph) on the open road, it returned 23 mpg (that's about 18.5 to the US gallon, I think) Not disappointed about that but now that I'm home, I have a job to do on it.
I'm guessing that the guy who restored the P/U in Manitoba (Canada) didn't know what he was doing when he chased the threads in the diff centre and that left them too loose to seal. Oil leaks around the larger end of the axle housings - so much so that I had to top it up twice during this trip. If there is an easy and a hard way to do a job, I prefer the easy one so this is what I propose doing. I'd like feedback if my plans are unworkable so as to save me turning an easy way into something else. I devised this while driving and I think I have a way of doing this repair without the diff centre coming out of its bearings wich would make reassembly a PITA.
10-08-2018, 11:35 PM | #2 |
Re: Diff leaking around the bolts
Are the bolts tight and not sealing or are the bolts not tightening up? Is it just leaking around the bolts? or are the housing bells leaking.
It its just the bolts not sealing but being tight you can take string and goob it up with avation #2 or #3 liquid wind the string around the bolt and tighten them up again. If the bells are leaking, bigger problem as the gaskets are shims as well as being gaskets. If you separate the bells you might or probably will destroy the gaskets. You may have to pull the rear end and do it right. Maybe the guru of rear ends, Tom Endy will chime in here. |
10-08-2018, 11:40 PM | #3 |
Since the housing gaskets set the carrier bearing preload that's a bad idea.Pull the assembly out of the car,set it up so you can work on it,spread spring and pull radius rods and go through the axle,search Tom Endy rear axle rebuild.
10-08-2018, 11:42 PM | #4 |
10-08-2018, 11:50 PM | #5 |
Before tearing it down drain and flush the banjo housing. Then just remove the bolts 1 at a time, clean them and use some blue locktite (my favorite) or gasket shellac. You might not have to do anything further.
10-09-2018, 12:02 AM | #6 |
10-09-2018, 12:05 AM | #7 |
I would re-torque all 20 banjo bolts to 35 ft. lbs. You will probably find that the two forward bolts on each side are loose. For some reason these four bolts tend to come loose. I believe there is some squirming of the rear axle housing that goes on.
If this does not stop the leaking, drain the banjo and remove each bolt one at a time and coat the threads with Indian Head seal and re-insert and re-torque. Tom Endy |
10-09-2018, 12:39 AM | #8 |
Permatex # 2 works well, to seal the bolt threads, one at a time. Permatex # 2 will stick to bolt threads, even when they're slightly oily!!!---TRUST me on this one!!!
Bill Williamson
10-09-2018, 09:13 AM | #9 | |
We used it on GM 6-71 diesels that leaked oil everywhere, worked great. Try the easy ways first, if they don't work then go to the more complicated way.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 10-09-2018 at 09:15 AM. Reason: Addition |
10-09-2018, 10:36 AM | #10 | |
Thanks for the SIMPLE approach! For the Guy that rips the rear end out & tears it apart, "someone" will say, "Might as well overhaul the trans, replace the clutch & don't forget the pilot bearing & dial in the bellhousing---SO where does it END????----!7 MONTHS later, the car's BACK on the ROAD AGAIN---NLOL Bill Simple
10-09-2018, 01:21 AM | #11 |
I've got a diff here that I "rebuilt" when I didn't know what I was doing.
Leaks like a sieve too. |
10-09-2018, 01:33 AM | #12 |
Thanks for the replies so far guys. I am aware that the gaskets set the peload on the carrier bearings and if one os so munched up that I have to replace it, I'd do so with one of the same thickness. I've tried taking the bolts out one at a time and sealing them but not with a piece of string (or cotton?). I am not aware of Indian Head sealer - never seen it here. This edit is because I have just googled Indian Head thread sealer. I found a blister pack for $US4.99 with delivery of $65.74. Welcome to our world!!
Looks like I will try to find some Permatex #2, drain the diff, clean the bolt threads and the female thread in the housing, wrap some cotton on it and reinsert, torque to 35 ftlb and pray. I also wondered about a soft(ish) flat washer under the head of the bolts and some yellow teflon tape.. I dismissed babana peels!
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 10-09-2018 at 01:43 AM. |
10-09-2018, 01:44 AM | #13 |
Use loctite 515 on the thre ads,if the gasket is RS, take the old one out measure the thickness,get a new one ,cut it so you can slip it ove the axle,saving pulling it all to bits,when you make the cut ,do it in a dovetail so when you assemble it it will not leak,and put some 515 on the dovetail ,put the dovetail join at the top.
We are having a great trip home,tonight at Warren, Car and Carol both going great. |
10-09-2018, 03:05 AM | #14 | |
Does loctite 515 work on oily threads?
10-09-2018, 08:11 AM | #15 |
Modern sealants work better on antique cars than period sealants..permatex #2? indian head shellac? really?why not tamp a little oakum in there?
When you disturb a fixed housing adjustment you are basically resetting the preload. When you assume a leaking housing gasket is set at proper preload you make your first mistake,you double down by smearing sealant without regard to its loaded thickness altering the setting.Don't lowball your model A,do it right. |
10-09-2018, 08:13 AM | #16 |
You can get Indian Head on ebay.com.au from Lithuania for about $2.30 postage.
As it is a flamable liquid you might end up in the "midnight express" jail if you try to buy it. I'm sure someone on Fordbarn could send you a cake with a file in it, if that helps. "Modern sealants work better on antique cars than period sealants..permatex #2? indian head shellac? really?why not tamp a little oakum in there" From what I remenmber, when Mitch (a modern day mechanic) was on this forum, he used Indian Head and didn't have any leaks. Last edited by updraught; 10-09-2018 at 08:50 AM. |
10-09-2018, 09:02 AM | #17 | |
10-09-2018, 08:49 AM | #18 |
Come on, it's Australia, them's all outlaws down there, and they can bake their own cakes with files right there in the hoos-cow.
Seriously, Elvira has a minor version of this problem, and I did as Tom Endy suggests, with good success. Then, 6 months later, a few drips appeared again. Thourough cleaning and careful watching indicates leaking bolts again, not the gaskets. (I think!). Bolts are still tight, but seeping. (Best solution suggested by friends so far, run it without oil, when it burns up, replace it with one that doesn't leak. But, I'm going to not do that. I also rejected welding it all together. My friends are so helpful!) Might go for new bolts, and lots of thread hole cleaning, locktite on the threads since it should stay put, plus more string/Teflon tape to fill the gaps around the bell.. I don't like leaks, even small ones that only drip now and then.
Corley ----------------- Subscribed to the KISS principle! |
10-09-2018, 11:27 AM | #19 |
From a newer member and A hobbyist.
I understand both sides of this. The; if it isn't broke don't fix it, and the as long as you are there, freshen worn parts. I read all the multiple opinions, and hopefully learn and retain the info. IMO it depends on the owner and the condition of the car. If the owner is not a mechanic, and car condition is unknown, perhaps best to inspect and freshen parts if things are disassembled for something else. Another reason is reliability and not constantly wondering what's next when condition is unknown. For the more experienced members with cars in great shape, known history of the car, cars well maintained, and are mechanics - I totally agree with just fix what is needed for the current issue. |
10-09-2018, 02:27 PM | #20 |
I prefer Permatex High Tack gasket sealant over #2. You can buy it in spray or brush on. I've used it on my differential housings, transmission, and over 6k miles no leaks. I also used Ultra Black under the head of the bolt and medium strength on the threads.
