02-27-2017, 03:49 PM | #21 |
Re: Water & bubbles through head stud nut threads
As I recall it, 2 is correct but that was not a Russian B block. Maybe the Ruskies did it different!
02-27-2017, 04:20 PM | #22 |
Last edited by Mitch//pa; 02-27-2017 at 04:22 PM. Reason: Double post cannot delete |
02-27-2017, 04:20 PM | #23 |
02-27-2017, 05:37 PM | #24 |
I agree - twice is not enough. I've seen some on this forum say they check the tension at each service. I think that once no more movement can be achieved at a re-torque, that is probably more than is needed but good insurance. IMHO, unless there hes been some "event" like over heating, 3,000 miles is OK after no movement is felt at a tension check.
02-27-2017, 05:46 PM | #25 |
Just put a new head on, all new studs and nuts. Oozed up through the nuts for the first hour of run time. Sealed up all by it's self.
02-27-2017, 06:00 PM | #26 |
02-27-2017, 08:55 PM | #27 |
Happy to report it stopped leaking! I pulled and sealed the stud with the distributor clamp (the easy one to get out) and the other two stud leaks went away over time. Re-torqued the stud nuts again, 4 moved but most were tight. Starts right up and idles nice, just waiting for a rebuilt carb to get here from FedEx and I'll be good to go!
02-27-2017, 08:57 PM | #28 |
Great report.
Technician in a can was not needed |
