05-23-2020, 11:08 AM | #1 |
Correct paint color for gravel shield
Are all the gravel shields on 1957 Fords (mine is a Country Sedan) painted the same color? Mine appears to have been gray, although the car is red and white. Is there a name or a code for it? Also it appears the air cleaner is the same color. Is that correct?
05-23-2020, 11:25 AM | #2 |
Re: Correct paint color for gravel shield
I think the color you are looking for is called Ford Argent.
Ford Argent / #868992 Hex Color Code #868992 Paint Chip The hexadecimal color code #868992 is a shade of blue. In the RGB color model #868992 is comprised of 52.55% red, 53.73% green and 57.25% blue. In the HSL color space #868992 has a hue of 225° (degrees), 5% saturation and 55% lightness. This color has an approximate wavelength of 474.08 nm. Last edited by Merc Cruzer; 05-23-2020 at 03:33 PM. |
05-23-2020, 01:42 PM | #3 |
05-23-2020, 03:17 PM | #4 |
I think, this seems to be what he is talking about.
05-23-2020, 04:01 PM | #5 |
Ok, the gravel shield between the bumper and grille... Thanks.
On a '57 Bird those pieces are much smaller, only at the outer corners and body color. So not 'all' the '57 Ford gravel shields, if that matters. . Last edited by dmsfrr; 05-25-2020 at 09:17 PM. |
05-25-2020, 06:06 AM | #6 |
05-25-2020, 08:02 PM | #7 |
Thanks guys. That is what I needed to know.
