09-16-2020, 03:02 AM | #21 | |
Re: Thread - I screwed up
The only exception is if it were a reverse flow system.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-17-2020 at 03:43 AM. |
09-16-2020, 07:51 AM | #22 |
From my perspective, don't think it matters all that much. You're trying to turn the fan on when the water gets to a certain temperature, hoping that once it gets turned on that it generates enough air-flow to cool the water of the whole circulating system before it boils. Is 170 degrees that magic number for where you're installing it . . . who knows. I'd prefer an adjustable sensor/switch, but I'd try yours first and see where it comes on in reference to what your temp gauge is telling you. You'll soon find out if it is too late . . . or not. Report back on what you find . . .
09-16-2020, 03:19 PM | #23 | |
https://www.hotrod.com/articles/tech...itch-location/ I don't know....possibly a different hobby like knitting, where there are far fewer difficult technical decisions to worry about. |
09-16-2020, 03:39 PM | #24 |
Here is a quote from the linked article.
"The temperature probe should be plugged into the system where the coolant is hottest—generally, the thermostat housing, in the coolant passages adjacent to it, or in the water jacket of the cylinder heads." |
09-16-2020, 07:55 PM | #25 |
Sure looks like we are taking something simple and trying to make it difficult. As Bob posted:
"The temperature probe should be plugged into the system where the coolant is hottest—generally, the thermostat housing, in the coolant passages adjacent to it, or in the water jacket of the cylinder heads." Now if you have an adjustable probe turn on temp probe (which I use on one of my vehicles) or you can select lower turn on temperature probe you might be able to work it out. But, why take something so simple and make it difficult? I have a digital controller that I can adjust the temperature that the fan kicks in from the drivers seat and it provides a digital readout. It also is linked to the AC compressor and has a cooldown timer when the engine is turned off. If you want to go to all this trouble, then I would suggest this type of setup. |
09-17-2020, 08:15 AM | #26 |
The engine thermostats control engine temperature The fan sensor SHOULD read the water temperature at the bottom tank/inlet side of the water pumps. There is no point in running the fan when the coolant temp is already below that of the engine thermostat |
09-17-2020, 08:43 AM | #27 | |
09-17-2020, 09:00 AM | #28 |
not to be argumentative but there is no benefit in running the fan unless the radiator is unable to shed the heat load. Most of the time a proper sized cooling system will rid itself of the heat load just moving thru the air.
When my car is setting at a stoplight the fan will cycle. As soon as it's moving you can watch the temperature gauge move down and the fan shut down even on 100 degree days |
09-17-2020, 10:55 AM | #29 | |
09-17-2020, 01:22 PM | #30 | |
09-18-2020, 11:07 AM | #31 |
Put a manuel switch on it..if ur old like me add a "idiot light" to it so your reminded if it's on or not..
09-19-2020, 12:00 AM | #32 |
I don't know....possibly a different hobby like knitting, where there are far fewer difficult technical decisions to worry about.[/QUOTE]
Frankly I find this quite rude. Opinions are fine but personal attacks bother me when one member seeks advice and another member denigrates. Similar to posts on the other FB. |
09-19-2020, 01:33 AM | #33 |
HEY CALM DOWN as said in my post 16 it will work provided our friend has the correct temp switch for his location and conditions as he is still monitoring the coolant temp just its what is going into the eng not what is coming out so the switch settings will need to be a lot lower than what is considered normal when its placed at the thermostat and as i said before toyota already do this with some of their diesels . So in answer to our friends question yes it will work but a lot of experimenting will be required JUST CAUSE ITs DIFFERANT DONT MEAN ITS WRONG
09-20-2020, 11:28 PM | #34 |
When I started this thread I was really interested learning only the thread size of the petcock. Yes, I did post a link which undermines the theory of my situation but I did as I was told, right or not.
I am glad and thank you all for the ideas presented. My conclusion now is: my sensor is in the WRONG place, at the bottom, it's gonna stay there, and it will work. Sort of. Thanks everyone for your thoughts. |
09-21-2020, 02:51 AM | #35 |
If you have a reliable temp gauge you could always rig an override switch so you can turn it on manually if stuck in traffic on a hot day and start feeling nervous. I have electric fans on my three on the road flathead powered cars and all they have is a manual switch.
Mart. |
