09-23-2011, 06:10 AM | #1 |
powermaster alt
Has anyone had any issuse with one of powermaster alternators? Mine is 2yrs old and has less than 2000 miles on it. Just reworked valves and reinstalled it and had some charging issues. Volt meter dropped like a lead ball when I turned on the lights. Charged battery last night to elimate that, plus its a new battery.
09-23-2011, 07:45 AM | #2 |
Re: powermaster alt
Make sure everything is grounded properly.
09-23-2011, 07:55 AM | #3 |
Re: powermaster alt
I bought a chrome one at one of the car shows. It ate the rear armature bearing early on. I thought it was a fluke and replaced it myself. That one went bad. I installed my spare and took it back to Powermaster at the next show. They repaired it and sent it back to me. Did the same thing and I gave up. I guess that is what they wanted me to do.
09-23-2011, 09:19 AM | #4 |
Re: powermaster alt
I had one with very low mileage which became a problem. I put a spare on and it has been going for several years. Don't remember the brand of the spare?
09-23-2011, 10:16 AM | #5 |
Re: powermaster alt
3-wire http://www.dbelectrical.com/c-8468-110-amp.aspx
or 1-wire http://www.dbelectrical.com/c-8471-110-amp.aspx Jack E/NJ |
09-23-2011, 10:21 AM | #6 |
Re: powermaster alt
09-23-2011, 10:34 AM | #7 |
Re: powermaster alt
Had a powermaster alt. the one that looked like an generator, lasted about 5 miles then quit they were sending a new one but in the mean time i took it apart, looked like it would never last as there was not way air could come in from the rear to cool the rectifier or diodes, cooling air in alt goes from rear to front, so i returned it and put one a regular Delco alt. newer style like off 90 gm pickup works great and fits with the three carbs. Laurie
09-23-2011, 11:20 AM | #8 |
Re: powermaster alt
No experience with Powermaster, but I've had one of Ed Whitney's lookalike conversions going on six years with no problems. He advertises in the V8 Times.
09-23-2011, 12:13 PM | #9 | |
Re: powermaster alt
09-23-2011, 07:52 PM | #10 |
Re: powermaster alt
That is what I have run on my 37 since startup 4 years ago an Ed Whitney alternator inside his special made case with 37 ends.
"Never complain,never explain"... Henry Ford II |
09-24-2011, 02:52 PM | #11 |
Re: powermaster alt
Was looking @ powermaster alt's but I am going with Certified Auto Electrics bracket and kit using a Ford alternator for my 59AB.
Will post pic's after install and let you know how it holds up Certifiedautoelectric.com, 888-597-8278. there add was in the July/Aug V8 times on page 5. |
09-24-2011, 03:37 PM | #12 |
Re: powermaster alt
Looks like the route I will go especially since they are only 40 mnts away from our house here.
09-24-2011, 06:02 PM | #13 |
Re: powermaster alt
powermaster = crap what a way to flush down $400. So much for that original look. I took this thing apart and it must be made by children.
09-25-2011, 12:24 AM | #14 |
Re: powermaster alt
If you're looking for a stock look, the PowerGens are a larger diameter and may conflict with correct accessories. Go with an Ed Whitney alternator conversion or convert your generator from 6V to 12V...that's what I did...4 yrs no issues. Only one drawback, the 12V gen doesn't have the amperage output of an alternator but it's not an issue for me...my 2 cents...
COE Dan |
09-25-2011, 10:42 AM | #15 |
Re: powermaster alt
I'm at that point to have my gen reworked to 12v. Since I dont really have any accesories to worry about truck is mostly stock. Certified auto has an alternator kit for under 150, and they are less than 40 mnts away, they can also rewind this piece of crap powermaster turd and also my generator. Going to get prices for those items. Just completely frustratedabout spending big mone on items that are made overseas and pieces of garabage. I finally have my truck together to drive and now I cant because of stuff made in china
09-25-2011, 01:40 PM | #16 |
Re: powermaster alt
47 flatbed...I hear your frustration...I didn't got the powergen route because the air cleaner brackets won't fit around the larger diameter powergen...guess I got lucky there. But I have spent much more than I'd care to shipping inferior parts back to big name suppliers...
COE Dan |
09-25-2011, 04:02 PM | #17 |
Re: powermaster alt
Several yeas ago I built 7 6 volt alternators into 39-48 2 brush generator houseings I ran one over 4,000 miles last year. 1,200 miles in 22 hours twice at 65 plus MPH and no problems. They are 12 volt standard Nippendenso ???? but with a 6 volt adjustable regulatator and reverse polarity diodes I adjust it to 7.5 volts at driving speed and with a standard small diameter stock Ford pulley it idles at 6.85 and comes up to 7.5 with just a few RPMs above idle or a fast idle. It's only about 25 amps but that's plenty for me. When my hard drive crashed I lost the pictures but in Oct. when I get back to Florida if anyone is interested I'll take some more and post rough instructions and parts. I am not interested in building them. It requires a special shaft adaptor which I could get someone to make if needed. G.M.
www.fordcollector.com |
09-25-2011, 06:07 PM | #18 |
Re: powermaster alt
GM, the info on your conversion would definitely be of interest. Please post when you get the chance. Thanks in advance, John
09-25-2011, 08:25 PM | #19 |
Re: powermaster alt
I would like to build one of these my self. Thanks for all great information.
09-26-2011, 07:54 AM | #20 |
Re: powermaster alt
Send me a PM in mid Oct. so I don't forget. G.M.
