Old 09-18-2019, 07:57 AM   #1
Vanspeed
Vanspeed's Avatar
Default How many cc’s??
How many cc’s are stock heads? How many cc’s are Snyders 6:1 heads? I have a post saved from a few years ago where Bob Johnston says a 5:5 is 149 and a 6:1 is 137. According to Snyders catalog a 6:1 is 152. Who is right?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 09-18-2019, 10:42 AM   #2
Jim Brierley
Default Re: How many cc’s??
I have a chart in my book, done by Dave Barker some years ago, showing compression ratios using different bore sizes. It shows 155 for standard bore, 6:1 head. And it shows about 240 cc's for 4.2:1.
Jim Brierley is offline   Reply With Quote
Old 09-18-2019, 12:23 PM   #3
Vanspeed
Vanspeed's Avatar
I bought a head and it measures 125 cc. Just trying to figure out the compression ratio of it.
Old 09-18-2019, 02:22 PM   #4
PC/SR
This site has an on line calculator. Just plug in the numbers. http://www.csgnetwork.com/compcalc.html
PC/SR is offline   Reply With Quote
Old 09-18-2019, 10:01 PM   #5
Nosetime
Nosetime's Avatar
@Vanspeed. Buy Jim's book!
Nosetime is offline   Reply With Quote
Old 09-20-2019, 11:32 AM   #6
Jim Brierley
My chart shows 7.5:1 for 125 cc's, you'll need to add in the gasket volume, I've seen 16.877cc @ .050” thickness and 20.253cc @ .060”. Marco Tahtaras on Ford Barn says 17.474cc. I’ve been using 20cc, a nice round figure. 145 is about 6.5:1
Old 09-21-2019, 09:36 AM   #7
redmodelt
redmodelt's Avatar
Wouldn't any piston pop up negate the the added cc's for the gasket thickness? For example if the block had been decked or other reasons.
Old 09-21-2019, 09:47 AM   #8
Jim Brierley
Good point redmodelt! Yes, piston pop-up means fewer cc's of combustion chamber volume. It's normally about .015" but should be measured. At least .040" clearance should be maintained between the piston and the head as rods will stretch at high RPM's.
Old 09-23-2019, 10:42 AM   #9
Vanspeed
Vanspeed's Avatar
Thanks for the info guys. I have yet to pull the stock head to measure piston pop up if any.
