07-07-2022, 06:37 AM | #1 |
Keeping hub caps on
I've had the front hubcaps come flying off more than once when I hit a bump. Bent the 'teeth" out a tad after sharpening them for a better bite on the rim, used double sided Gorilla Tape on the hub where the cap edge contacts the rim. So far they are holding but do loosen up after a drive. Any other ideas as damage to the cap will result in anymore launchings off the rims? I was thinking maybe silicone?
Don |
07-07-2022, 08:44 AM | #2 |
Re: Keeping hub caps on
Do you have radial tires? If so it's your rims flexing.
A man should do what he thinks best! "The Duke" |
07-07-2022, 09:26 AM | #3 |
I only have one surviving full wheel disk for the 52 Merc and I won't drive with it anymore. It just won't stay on and as some say it might be because I'm using radial tires. I use the small "dog dish" caps instead. Never lost one of them yet.
https://www.youtube.com/user/roosty6/videos |
07-07-2022, 10:31 AM | #4 |
I've lost my share of caps with bias plys too, so I'm not sure I dig that whole argument. But I've found bending the tangs out until they have to be tapped on with a rubber mallet keeps them on tight.
07-07-2022, 02:19 PM | #5 |
I have radials.......smooth ride compared the hard ride bias tires give you, which one would think, would shed caps even more. I bent the tangs also as I explained above and that seems to have solved the problem (so far) but I was fishing for additional holding ideas. Yes, bending as well as sharpening the tangs does require a rubber mallet application
07-07-2022, 03:13 PM | #6 |
Paul in CT |
07-07-2022, 05:18 PM | #7 |
This is what the Dog Dish hubcap for the Mercury looks like. It was introduced in 1952 and continued on during the fifties. I believe that the centres on the 52 to 54 Mercury were painted Red. This 1953 Mercury Convertible has these small hubcaps on and they look good. Not sure about the colour for 1953, but I do know that in 1956, it was White. Also not sure of the last year for this shape hubcap. Maybe, someone can fill me in? |
07-07-2022, 05:43 PM | #8 |
The small Merc caps with a trim ring look as nice as the full caps in my opinion. Not likely to lose the small caps.
07-07-2022, 07:22 PM | #9 |
I was losing the caps ff of my 1936 Sedan. Applies a few dabs of RTV Sealer to help hold them in place.
07-07-2022, 09:09 PM | #10 |
A bit of insurance with a sharpie print your name and phone number. If lost maybe a kind hearted sole we I'll find it and call you 7
07-07-2022, 10:27 PM | #11 |
I feel just the opposite on radials vs bias. The steel belted radials seem to feel every little rock in the road. Maybe I just wasn't paying attention 50+ years ago when riding in the Merc with my dad driving. It seemed a very smooth ride on bias ply blackwalls back then. Even with the pressure down in the 25 pound range now it seems like a hard ride with radials. Not bad on pavement of course.
07-08-2022, 06:38 AM | #12 |
search "Hub Cap Clips" on Amazon. I adapted some of the old medal Chevy clips to work on my '52 F-1. These Dune Buggy ones might work??? Chap
https://www.amazon.com/CLIPS-RIVETS-...%2C105&sr=8-10 |
07-08-2022, 06:59 AM | #13 | |
07-08-2022, 07:19 AM | #14 |
I still have a full set of the original 53' Merc hubcaps. When I finally got tired of picking them up from the side of the road, I used them for wall art.
07-08-2022, 07:23 AM | #15 |
07-08-2022, 07:26 AM | #16 | |
I bought my original set of for for $100 back on 1/19/10. A friend of ours bought a set for her car, off of e-bay, a couple of years ago and paid just over $230. It took her a coupe of months to find them. Yes I do think that is outrageous. Keep searching e-bay and try to get out to a few swap meets this summer and I think you will do allot better. They are out there. They usually get listed as 55'-56' Mercury. That might help your search. Good luck in oyu search Last edited by Merc Cruzer; 07-08-2022 at 07:49 AM. |
07-08-2022, 07:32 AM | #17 | |
07-08-2022, 07:35 AM | #18 |
Love that car of yours Merc Cruzer.
07-08-2022, 07:45 AM | #19 |
Thank you. It has been a journey, but one well worth taking.
07-08-2022, 07:47 AM | #20 |
