Old 09-19-2018, 11:16 AM   #1
johnbuckley
johnbuckley's Avatar
Default Frame year ID
Can some one date the year of production of this frame please?
johnbuckley is offline   Reply With Quote
Old 09-19-2018, 12:09 PM   #2
Bob C
Default Re: Frame year ID
Going by the emergency brake cross shaft it's before April 1930, can't
see the front cross member very well to tell if it's a 1930.
Old 09-19-2018, 12:21 PM   #3
40 Deluxe
How about using the serial number?
40 Deluxe is online now   Reply With Quote
Old 09-19-2018, 12:30 PM   #4
Richardt2k
Richardt2k's Avatar
I have a chart that gives every month and year for every Modle a made. From first to the last It’s in my pictures. But Don’t know how or have a way to post it. If someone will pm me with e regular email address I’ll email it to them and maybe they can post it. It’s a really good chart
Richardt2k is offline   Reply With Quote
Old 09-19-2018, 12:41 PM   #5
johnbuckley
no fame number visible/decipherable
Old 09-19-2018, 12:43 PM   #6
Richardt2k
Richardt2k's Avatar
The frame and motor have the same number. If the motor is original
Old 09-19-2018, 12:45 PM   #7
Richardt2k
Richardt2k's Avatar
Look behind the first cab bolt,drives side top of frame
Old 09-19-2018, 12:49 PM   #8
George Miller
George Miller's Avatar
I say 1929 but not sure.
George Miller is offline   Reply With Quote
Old 09-19-2018, 01:43 PM   #9
Badpuppy
Steve Plucker has done exhaustive research on the subject. You can probably figure it out from the pages on his website -
http://www.plucks329s.org/frame.htm
Badpuppy is offline   Reply With Quote
Old 09-19-2018, 02:03 PM   #10
john in illinois
john in illinois's Avatar
The 28-29s had holes for rhd and lhd steering in the frame rail and 30-31 only had lhd ,at least
at least in US cars.
John
john in illinois is offline   Reply With Quote
Old 09-19-2018, 03:17 PM   #11
Richardt2k
Richardt2k's Avatar
Good stuff. Thanks for sharing the link.
Old 09-19-2018, 04:11 PM   #12
flatford39
The radiator support bases appear to be raised but really hard to tell from your pics. If the are then it's 28 29.
flatford39 is offline   Reply With Quote
Old 09-19-2018, 06:42 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
It looks like the radiator mounting is dipped, which started in late 29.
1928-9 has round holes to mount the radiator, and 1930-1 has slotted.
Old 09-20-2018, 01:46 AM   #14
johnbuckley
Thank you everyone
Old 09-20-2018, 08:14 AM   #15
midgetracer
midgetracer's Avatar
I was always under the belief that the middle cross member with the odd shaped holes (where they punched out the brake rod anti rattler brackets) was 1930 or later. I also thought that the 29 and earlier had square holes in that position. Maybe I am wrong.
midgetracer is offline   Reply With Quote
Old 09-20-2018, 10:53 PM   #16
john charlton
john charlton's Avatar
You can see that the frame can be accurately dated as it is in the short time frame when the frame has been punched to take the solid bar emergency brake cross shaft. This frame has the earlier drop down hollow shaft typical of 28/29 .It will have factory blanking plates to stop the ingress of road dirt entering the brass cup bearing ends of the shaft. Ford brought out the frame holes then continued using up the early style . It is in the Service Bulletins around early 30 I think but cant find my yellow book right now.
John in very windy heavy rain Suffolk County England.
john charlton is offline   Reply With Quote
