Old 07-19-2018, 12:18 PM   #1
shoe box Jack
Default dyno
Last weekend I had a chance to put the 49 on a dyno. The engine is a260 cu 4 inch. by 30 thou. isky. cam 77-b stock heads cut 60 stock intake with one ford 94 carb fenton headers with 2 smittes ss chev. valves and bubbas dissey. at 3,820 rpm max power 82.39. at 2,590 rpm max torque 157.22. Just a little bit of nothing news. jack
shoe box Jack is offline   Reply With Quote
Old 07-19-2018, 04:22 PM   #2
flatjack9
flatjack9's Avatar
Default Re: dyno
Engine dyno or chassis dyno?
Old 07-19-2018, 04:59 PM   #3
shoe box Jack
Default Re: dyno
chassis dyno. It was a hoot to do, a first for me. Jack.
Old 07-19-2018, 07:03 PM   #4
flatjack9
flatjack9's Avatar
Default Re: dyno
So what do they project as the drivetrain loss?
Old 07-19-2018, 08:07 PM   #5
shoe box Jack
Default Re: dyno
The operator told me that the average loss is 15%, I don't know the horse power of the 49 engine but I would guess it would have 120 hp?. Jack.
Old 07-19-2018, 09:29 PM   #6
scicala
scicala's Avatar
Default Re: dyno
What was the rear wheel horsepower ?
Sal
scicala is offline   Reply With Quote
Old 07-20-2018, 04:37 AM   #7
JWL
Default Re: dyno
That sounds really close to me. I also think 15% drive train loss at such low speeds is over stating the issue. Most people do not realize the work necessary to make an honest 130 HP with our Flatheads.
If you want bigger numbers you can go to New Mexico.
JWL is offline   Reply With Quote
Old 07-20-2018, 07:24 AM   #8
shoe box Jack
Default Re: dyno
Hi Sal, The HP. at rear wheels is 82HP.
Old 07-20-2018, 04:31 PM   #9
scicala
scicala's Avatar
Default Re: dyno
Thank you shoe box Jack.
Sal
Old 07-20-2018, 05:12 PM   #10
GOSFAST
GOSFAST's Avatar
Default Re: dyno
If the rear wheel HP numbers are correct you have about 100 HP at the flywheel!
We have a couple very experienced chassis dyno operators in our area and just about all feel comfortable with a 16% to 18% power loss through the drivetrain!
Thanks, Gary in N.Y.
P.S. For the parts you mention in your build above this 100 HP number is really not all that bad, it should still be fun ride!
GOSFAST is offline   Reply With Quote
Old 07-22-2018, 05:21 AM   #11
JWL
Default Re: dyno
For those of you who might be interested enough to learn about drivetrain power loss I suggest you read the SAE (Society of Automotive Engineers) papers on this subject. As you might guess they have conducted testing and written extensively about the subject. You will soon see the 15, 16, 18 percent BS is just that. As a matter of fact all cars are different and using a standard number is pathetically uninformed.
Old 07-22-2018, 11:04 AM   #12
Bored&Stroked
Bored&Stroked's Avatar
Default Re: dyno
When I recently put my 32 Cabriolet on a chassis dyno at Ida Automotive (before TROG), it made just under 150 HP at the rear wheels. It is a heavily modified 284 cubic inch engine, big ports, huge roller cam, etc.. It only has two Stromberg 48's on it - so it is most likely a bit under-carbed. It easily revved to 5500 in all three gears. It is not easy to get to even these HP numbers on a street engine (without a blower) - this engine probably makes about 170 - 175 HP at the flywheel. It is running an Eddie Meyer hi-rise two-pot manifold (not the best for the engine size - but it sure looks good). I'm going to port the top manifold piece and try a set of Holley 2110 carbs - just for shits and giggles (and go back to the same dyno). Of course I need to replace the rear end first . . . the early 32 rear did NOT like that dyno run! LOL
