View Poll Results: Do you run temp and oil pressure gauges | |||
Do you run a Thermostat? | 102 | 40.80% | |
Do you run a Temp Gauge? | 106 | 42.40% | |
Do you run a Oil Pressure Gauge? | 39 | 15.60% | |
Do you run with both gauges? | 55 | 22.00% | |
Dont run any of the above gauges? | 93 | 37.20% | |
Multiple Choice Poll. Voters: 250. You may not vote on this poll |
03-30-2013, 11:20 AM | #1 |
How many run Temp & OR Oil Pres. POLL?? UPDATED WITH TIME TO WARM UP Pic
Just was curious to how many installed one in their A.. with our without a thermostat...
This picture of my clock represents the actual WARM UP TIME with following the temp gauge. The car was sitting outside for 8 hours and the temp was 40 degrees.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe Last edited by msmaron; 04-02-2013 at 11:34 AM. Reason: txt |
03-30-2013, 12:54 PM | #2 |
Re: Curious How many run a Temp Gauge & OR Oil Pres. Gauge POLL??
I run oil pressure guage =5-7Lbs is normal and a 170* Thermostat and an important addition is the Fan Shroud from a "AA" Truck
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford |
03-30-2013, 01:00 PM | #3 |
Planning on running a temp gauge and oil pressure gauge, have both. The oil pressure gauge is likely more for looks than being really useful. Not sure about a thermostat, that will depend more on the running charactoristics of the engine when done. Also may run a tach if I can find a small one that looks vintage. Rod
03-30-2013, 01:02 PM | #4 |
Thermostat, Water temp, Tach, Oil Press, Clock. Don't know where I'd put it or I'd have a vacuum gauge.
03-30-2013, 01:44 PM | #5 |
never have run either.... motormeter is all you need.....
03-30-2013, 02:19 PM | #6 |
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
03-30-2013, 02:20 PM | #7 |
Run a t/stat, both gages, and have an old s/warner motometer (vac Gage) to be installed.
Paul in CT |
03-30-2013, 02:29 PM | #8 |
I was running the oil gauge and that is now on the shelf as it really does nothing at all, the temp gauge i am going to install as i have been running a thermo. and will allow me to know when to RUN And GO!!!
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
03-30-2013, 04:01 PM | #9 |
lets get some more votes to see some real numbers fordbarners!!! this is getting interesting
03-30-2013, 04:24 PM | #10 |
Just a murdermeter......does that count as a gauge?
My coupe had a dead motormeter when I bought it, and I had to shell out $55 plus, to replace the entire top end, cause vendor reports no thermometers available from manufacturer. Hmmmm...something about "too difficult to install". Actually the thermometer simply unscrews from the bottom of the "wreath"....easy peasy. |
03-30-2013, 06:56 PM | #11 |
Right now I'm running both gauges without the thermostat. I plan on installing a thermostat at a later time before I drive her more. She's a new to me motor and even though the oil doesn't show much pressure upon warm up, until everything is more familiar it’s just a good piece of mind to see the pressure at startup. With the older radiator and conditions here in Florida I won't run without a temp gauge.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
03-30-2013, 07:24 PM | #12 |
Left to right. Oil,gas,water.
03-30-2013, 07:26 PM | #13 |
I am also using a volt meter,mostly because of the alternator,and the amp meter not registrating after a few minutes of running.
03-30-2013, 08:43 PM | #14 |
I only use the motometer and ammeter. No thermostat or temp gage or oil gage.
03-31-2013, 02:10 AM | #15 |
03-31-2013, 02:47 AM | #16 |
Never found a need to in all the years I've had my A.
03-31-2013, 02:57 AM | #17 |
I'm running a steam guage. When steam comes out the overflow pipe, the engine is too hot.
03-31-2013, 07:48 AM | #18 |
I worried about not having these gauges when I first got my A. What if... what if... Only after thousands of miles did the worry and fear go away. I don't even think about them now.
Ray White |
03-31-2013, 08:08 AM | #19 |
I counted my THERMO-QUAIL as NO temp gauge as the one time I overheated I looked at the thermo quail and it was still NOT REGISTERING as always.
Does anyone's thermo-quail ever show any RED? Thanks. |
03-31-2013, 09:59 AM | #20 |
I don't run any of them. Motometer in the radiator is all that is needed.
The rest is just not needed.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
