09-22-2018, 11:17 AM | #1 |
priming an oil pump
How do I prime a model A oil pump already installed in the engine?
09-22-2018, 11:25 AM | #2 |
Re: priming an oil pump
I have never primed the oil pump after reinstalling oil pan.
09-22-2018, 11:35 AM | #3 |
If it is in the oil it is already primed. If you want to circulate oil before starting crank a few revolutions before choking and starting.
09-22-2018, 11:58 AM | #4 |
you guys are right, the Model A and model B oil pump sits in the oil priming itself. The v8 oil pump does not sit in the oil because the filter canister is screwed together.
09-23-2018, 11:27 AM | #5 |
