Old 06-24-2020, 02:21 PM   #1
Admiral
Admiral's Avatar
Default What to look for in an oil pump
I’ve got a 1952 or ’53 block at the machine shop getting checked out. It seems like a pretty primo flathead. It turned over, has no cylinder ridges and zero sludge inside. I’ve partially disassembled the short-body oil pump to clean it and inspect everything. I think I can put it back together with new gaskets and run it as is. Is there anything in particular I should be looking for in there? It spins beautifully, the gears look great and there’s no discernible slop in the shaft. Just curious if anything else need to be looked at.
Admiral is offline   Reply With Quote
Old 06-24-2020, 02:35 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: What to look for in an oil pump
Sideplay in upper and lower bushing.
Any marks on gears or scoring in pumpbody from foreign objects taking a spin in there.
The axial play between gears and housing.
Springpressure and condition of pressure release valve seat.
That´s what i check and adjust...so i think you are on the right track !
Old 06-24-2020, 04:20 PM   #3
flatjack9
flatjack9's Avatar
Oil pumps are seldom worn out.
Old 06-25-2020, 09:47 AM   #4
Admiral
Admiral's Avatar
Thanks, guys! I think I'll button this pump back up.
