12-03-2018, 10:33 PM | #1 |
valve insert
Have a 1951 ford flatty need to know if the valve inserts go top or bottom looking in from the top of the valve trane ???
TU W6WR |
12-03-2018, 10:45 PM | #2 |
Re: valve insert
Huh? please explain?
12-03-2018, 10:49 PM | #3 |
Re: valve insert
The round inserts that make the valve spring longer
W6WR |
12-03-2018, 10:57 PM | #4 |
Re: valve insert
Still not getting it. Maybe someone can help. I'm a bit thick.
12-03-2018, 11:08 PM | #5 |
Re: valve insert
If you are talking about valve spring shims, they seat on the guide.
12-04-2018, 08:51 AM | #6 |
Re: valve insert
They are used (because of the longer valve) to provide correct valve spring pressure.
12-04-2018, 08:56 AM | #7 |
Re: valve insert
They shorten the valve spring (compress it) to account for valve length. This is all assuming you are referring to the shims, if not really have no idea what you are referring to. What you are attempting to achieve is a specified valve spring pressure in the assembly, say 50 to 60 lbs.
12-04-2018, 09:14 AM | #8 | |
Re: valve insert
12-04-2018, 09:23 AM | #9 |
Re: valve insert
They shorten the length of the actual spring (not counting the shim), but lengthen the effective length of the spring (including the shim). It all depends on how you look at it.
12-04-2018, 09:40 AM | #10 |
Re: valve insert
Even the term flathead is somewhat broad. Ford made 4-cylinder, 6-cylinder, and two different sizes of V8 not to mention the variations over the years. We can only assume that it's a V8. There are different valves and guides depending on the year of manufacture of the engine too.
1951 narrows it down to 8BA type V8 or H model 6. Are you using a high lift cam? Does this engine have rotator type valves? |
12-04-2018, 09:44 AM | #11 |
Re: valve insert
What tubman said. I guess it may depend on if you are referring to the valve spring or the assembly including the shims.
12-04-2018, 10:00 AM | #12 |
Re: valve insert
Tu all w6wr
