Old 05-19-2022, 08:03 PM   #1
JSRTUDOR
JSRTUDOR's Avatar
Default Windshield/ Gas cap
Dumb question, should the windshield frame hit the gas cap when opening it to its' fullest position? I have to remove the cap to extend the windshield all the way out, then put the cap back on.
JSRTUDOR is offline   Reply With Quote
Old 05-19-2022, 09:04 PM   #2
TerryH
TerryH's Avatar
Default Re: Windshield/ Gas cap
No….
TerryH is offline   Reply With Quote
Old 05-19-2022, 09:08 PM   #3
Mike Peters
Mike Peters's Avatar
No. The windshield should clear the gas cap when opening. Your wood screws holding the windshield at the top are coming loose from the windshield header.
Your wooden header may be getting soft, or just the screw holes. See if you can tighten the screws a bit to pull it back up. If not, take one screw out at time and put toothpicks in the open hole and replace the screw. Sometimes this works if your header isn't too soft or rottenj. Good luck.
Mike Peters is offline   Reply With Quote
Old 05-20-2022, 09:17 AM   #4
Brkile
I had the same problem with a brand new cap from Clastique (NOT the upholstery people). I talked to someone at Bert's Model A parts in Denver and he said that caps from that company were too tall. A new cap from Berts from another manufacturer solved the problem.
Brkile is offline   Reply With Quote
Old 05-20-2022, 11:20 AM   #5
JSRTUDOR
JSRTUDOR's Avatar
Thanks for the information everyone, I will do all your suggestions!
Old 05-20-2022, 12:15 PM   #6
RubiconToad
I had this same issue on my 30 Tudor. It appeared the PO had installed a rubber gasket at the top of the windshield with the windshield in place. The gasket was doubled over in a few places, making it double thick at the top, preventing the frame from fully seating to the top header.
RubiconToad is offline   Reply With Quote
Old 05-20-2022, 04:45 PM   #7
JSRTUDOR
JSRTUDOR's Avatar
The gas cap sits about seven eights high. Windshield seems solid.
File Type: jpeg E7734108-1AEA-49D6-B0D7-6C4D2B754DE5.jpeg (70.5 KB, 59 views)
Old 05-20-2022, 04:59 PM   #8
arnhemmer
Originally Posted by JSRTUDOR View Post
The gas cap sits about one and seven eights high. Windshield seems solid.
That looks like 3/4 inch at the edge. My 1930 tudor shows the same height and it clears. Maybe you could loosen the screws at the header and possibly raise the windshield.
arnhemmer is offline   Reply With Quote
Old 05-20-2022, 05:56 PM   #9
Ruth
One and seven eights? 1⅞"? Looks like ⅞"> Glad you're not my machinist!
Ruth
Old 05-25-2022, 04:20 PM   #10
Keith Alvin
Take the cap off, stuff a rag in it. Just don't drive it when it's rainy. Windshield will now clear without issue.
Keith Alvin is offline   Reply With Quote
Old 05-25-2022, 11:25 PM   #11
lrf
When you drive at night, ignite that rag with a lighter, it'll give off more light than those headlights! JUST KIDDING!!
lrf is offline   Reply With Quote
