11-23-2017, 10:02 PM | #41 | |
Re: Noise in my new 29 a engin
11-24-2017, 08:53 AM | #42 |
Harryc! this food for thought! when I change the spark lever it would basically, in a round about way put more load on the cam in advance & less in retard! this would cause the noise too change, will need too think this one out! thanks
11-24-2017, 09:23 AM | #43 |
I think if & when I go back into the engine I will install the automatic timing advance system, for two reasons. it would regulate the timing that was needed by the engine when it needed it! it would also eliminate the chance of mistakenly advancing the timing too much & beating on the Babbitt in the rods & mains.
11-24-2017, 10:48 AM | #44 |
I don't know about "eliminating the chance of" . When you go to the automatic timing gismo, you still have to do the dance of where is the timing at idle and high speed with no regard for load on acceleration and climbing a hill. The first thing I would check if I were there is; the starting point at idle, Very Slow and not much power. After that, you have about 30-32 deg. to work with which is about 1/2 way down on the lever, maybe 2/3.
11-24-2017, 01:33 PM | #45 |
got a silly question? what are the dimensions of a 1929 model a radiator? it is hard to get a accurate measurement while it is on the car with the shroud & all!
12-07-2017, 09:10 AM | #46 |
12-07-2017, 09:53 AM | #47 | |
Hey Pinball,
Here is what happened to me ... might help you out. 06-03-2017, 01:14 PM #3 ________________________________________ My coupe suddenly started to make noise in 2nd gear about 5000 miles after a complete rebuild. All new shafts, all new Mark gears, bearings and etc. Looking back on it the only thing NOT replaced were the three needle bearings because they looked good. (HINT ... HINT) I lived with the noise by keeping speeds low in 2nd gear and drove another 5000 miles. Finally got tired of noise and tore it down. Found that one of the needle bearings inside the cluster gear had come apart so one end of cluster gear was "flopping around". Second/third slider gear and the corresponding gear on the cluster were "all chewed up". These were brand new Mark USA gears! I wonder if maybe I could have saved the 2nd gear and cluster by taking it apart as soon as the noise started! Your call !! Steve at Bert's said it was the noisiest transmission that he had ever heard. On the surviving needle bearings you can see that the needles are worn to "Points" where they fit into the holes in the "cage". Other wise the bearings look new. ________________________________________ Last edited by Benson; 06-03-2017 at 01:28 PM. Quote:
12-08-2017, 11:51 AM | #48 | |
Re: Noise in my ney 29 a engin
As far as wrist pins go, any movement that can be felt, is no good. The clearance should be right on at .005. Hope you find the problem. Herm. |
12-08-2017, 01:10 PM | #49 |
I know Herm meant .0005"
12-09-2017, 09:50 PM | #50 | |
12-09-2017, 11:28 PM | #51 | |
01-14-2018, 11:41 AM | #52 |
well, problem fixed I think! all new bearings in the transmission, new input shaft, replaced the cluster gear & second & high sliding gear, new cluster & reverse idler pins & a new u-joint! while doing all of this I also found the bracket that bolts the alternator too the block was loose & it had to be making noise! have not had it in the road yet, but pretty shore the noise is gone
01-14-2018, 11:48 AM | #53 |
got a question! I filled the transmission with Lucas gear additive, only! I was told that every one uses STP! the Lucas is about the viscosity as the STP, but it will not foam & it sticks to the gears better. what does every body think about doing this?
01-14-2018, 12:42 PM | #54 |
STP is not a lubricant it is an additive and so is Lucas. So, do two modifiers make a lubricant, not likely. Today's equivalent of 600 W is known as Steam Cylinder Oil and you will only find it at the local distributor, not at the auto parts store. Do a search here for "600 W". Remember, when your back on the road with your ears on, the consensus on timing was NOT all the way down. That is the sound of the engine crying and saying; back off, that's too much.
01-14-2018, 03:45 PM | #55 |
Most of the vendors carry 600 W oil.
Fred Kroon 1929 Std Coupe 1929 Huckster |
01-14-2018, 09:57 PM | #56 |
Lucas oil stabilizer works great as transmission grease. Shifts smooth as silk. Much better than the 600W oil I got from a vendor.
01-14-2018, 10:50 PM | #57 |
It could be a loose timing gear nut. A simple test is to insert timing pin into timing hole while the engine is running at idle speed. Slowly push pin against gear if the noise goes away it means either the nut is loose or the gear is worn. Sometimes a worn 2 piece gear will produce this type of noise.
