04-24-2020, 04:41 PM | #21 |
Re: Ignition problem no spark
Regardless of coil type, the first thing always suggested is the coil. The complete system needs to be gone through in a sequence. Just throwing parts at something gets expensive.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
04-25-2020, 04:26 PM | #22 |
Got more testing done today, put #1 cyl. TDC checked rotor position, it points to #1 dist. wire. So I don't have stripped dist. gear or timing gear damage. Wanted to get that out of the back of my pea size brain. Found info. that said if the ign. switch is left on for over 15 sec. it could damage the module. Also finally checked the air gap, its way over .030 and couldn't adjust it closer, hope the new one has instructions on that. Al
04-25-2020, 10:03 PM | #23 | |
Were you able to get the car back to the house? PERTRONIX has a TECH HOTLINE. Maybe they know something I don't (that wouldn't be difficult). There has to be a diagnostic sequence for their DIST.
04-26-2020, 10:22 AM | #24 |
Nope the car is still in storage, the gap on the module was so wide I could get 2 pieces of .030 plastic card between the shaft and module. Nothing is movable on the module plate so hope that's fine. I couldn't find any info. on replacing the Ignitor 2 module that mentioned the gap setting. I found the Help line no. and will call them to check it out. Thank you for helping me with problem, I can't bend over the hood much longer, old back don't like that. I'll keep in touch. Al
04-26-2020, 02:03 PM | #25 | |
04-26-2020, 03:28 PM | #26 |
04-26-2020, 03:50 PM | #27 |
Oem dist and a NAPA coil. At the time of installation I was too ignorant to do the complete assy but the NAPA guy whom I have known for years told me this set up should work. He said if it didn't he would refund my money and help me get the Flamethrower parts.
04-26-2020, 07:08 PM | #28 |
50 Ford mine is all Pertronix, Flamethrower dist. with Ignitor 2 module. There is no adjustment inside the dist. to move the moduel closer to the trigger shaft. I'm hopeing that's the way it's supposed to be. Been running the car with no problems for 2 yrs. or more with same setup, don't know yet what happened yet. Al
04-26-2020, 07:18 PM | #29 | |
04-28-2020, 04:42 PM | #30 |
I got my new module yesterday, called pertronix and talked to a service tech. He told me to run a ground wire from battery neg. to dist. housing with 12 volts on pos. side of coil and it should fire up. No spark I left the old module in for that test to see if it was good before changing it out. Had to quit because of weather, will try again tomorrow if storm has passed. 50ford the module on my Ignitor 2 has no slots in the mounting screw holes for adjusting the gap. The module mounts on a C shaped plate that mounts to a round plate in top of the dist. with no adjustment in either for setting gap. Al
04-28-2020, 05:22 PM | #31 | |
05-01-2020, 01:51 PM | #32 |
I got the module installed, that must have been the problem,because the car is now running. I set the engine on T D C, removed the dist. and installed the module. I talked to a tech support guy about the module, he said it was the correct one just had up grade and the one I had replaced my older one, and the air gap was not adjustable.I found whoever did the install had changed the wire color going to the coil. It was a black wire coming out of the dist. ,but was spliced to a green wire going to the coil. I had to strip the wire covering off to find which wire went to coil on negative side. Al
05-06-2020, 10:52 PM | #33 |
Well guess what, it no longer has spark. I talked to a service tech today and he gave me a way to test the new module. I had already called it a day at storage, so I tested the old one I had removed. It failed the test, so I will test the new one tomorrow, I think it may fail the test also. Al
05-08-2020, 01:00 PM | #34 |
The new module could not be tested like I was informed. That test was for the ignitor. That was for the Ignitor not for the Itgnitor 11, so am having a new one sent, maybe have some good results with it. Let you know. Al
05-11-2020, 09:01 PM | #35 |
Well I got the new pickup module installed today, works fine. Found a mess in the wiring harness, bringing it home tomorrow and going to fix that mess. I ordered a wiring diagram for a 55 Ford, should be here tomorrow. Need to find several different colored wires. The only thing that's not working now is the backup lights. Finally figured out the 2 relay's, one powers the push fan and the other one powers the 2 pull fans. The main feed wire was 3 different colors, had me scratching my head until I removed the cover over the wires. Al
05-12-2020, 10:49 AM | #36 |
I'm not big on Pertronix products myself. I almost always use a factory GM or Ford HEI distributor if I have the firewall space. I used them in stock cars with 8mm wires and they always pulled strong up to 7000 RPMs.
05-12-2020, 12:29 PM | #37 |
the Flamethrower dist. was in the car when I bought it. It ran good until the module went out, I think when I get the wiring fixed it will do ok. The coil had too many wires connected to the pos. terminal which may have lowered the voltage requirements for the unit, it has to have 12 volts to work properly.Al
