Old 06-15-2022, 05:28 AM   #1
updraught
updraught's Avatar
Default Something different speedster
https://www.carandclassic.com/car/C1425045
updraught is offline   Reply With Quote
Old 06-15-2022, 07:00 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Something different speedster
The carburetion treatment is interesting. I assume the carburetors are SU. There is cross over connection between the two separate intake manifolds.
Actually the whole car is interesting. Very nicely done. Thanks for the link.
Old 06-15-2022, 11:43 AM   #3
bavArian
bavArian's Avatar
Nice looking car, but I don't get why the builder didn't use matching instruments. Would look way better.
bavArian is offline   Reply With Quote
Old 06-15-2022, 07:27 PM   #4
Oldbluoval
Oldbluoval's Avatar
To each his own
That can be his …..
Oldbluoval is offline   Reply With Quote
Old 06-15-2022, 09:50 PM   #5
Synchro909
Synchro909's Avatar
Originally Posted by Oldbluoval View Post
To each his own
That can be his …..
What do you think are the chances he says something similar about our cars? Like you said, "To each his own."
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 06-16-2022, 06:23 AM   #6
ronn
Looks English, almost Morganesk!
regarding the SUs, prob had them laying around from an old triumph spitfire and hence, the mis matched instruments. was prob done on the cheap.
no different then many of the speedsters built. one's own interpretation.
I give the guy credit.
Old 06-16-2022, 10:23 AM   #7
katy
katy's Avatar
That's quite the coolant outlet, looks home made.
Old 06-16-2022, 10:25 AM   #8
nkaminar
nkaminar's Avatar
I cannot tell how the front spring is treated but in the rear you can see the cross member for the rear spring behind the seat, up high. Lowering the majority of the frame is, in my opinion, a good way to lower the center of gravity. If I was going to build a speedster, I am not, I would try and build it along these lines. I like the rear gas tank.
The whole car sort of looks like a 1922 Vauxhall 3-liter racing car except with wider tires. (Tyres.)
