Old 07-10-2018, 08:26 AM   #1
joltesvig
joltesvig's Avatar
Default Starter Switch Test
The starter key switch has armor all the way into the bottom of the distributor. I already replaced the spark coil with a new one. Still have no spark so I think the starter key switch has gone bad. Before going to all the trouble of replacing the key switch, I want to test it but the armor prevents me from doing a continuity test as far as I can tell. Is there an easy way to do a continuity test on the starter key switch?
John the Model A Rookie from North Carolina
joltesvig is offline   Reply With Quote
Old 07-10-2018, 01:46 PM   #2
Big hammer
Default Re: Starter Switch Test
In Brattons catalog they have a how to check out the switch! With long test leads you should be able to check it out. You’ll need to have access to the back of the panel that holds the switch.
get a bigger hammer tap done
Old 07-10-2018, 02:24 PM   #3
1930artdeco
1930artdeco's Avatar
Don't forget to check to see if it is grounding on the tank.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 07-10-2018, 04:47 PM   #4
joltesvig
joltesvig's Avatar
Thanks Big Hammer and thanks Mike! I have a Brattons catalogue...I’ll check it out!
Old 07-11-2018, 09:44 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
With open points and key ON, you should have 6 volts at the movable point contact.
Old 07-11-2018, 06:49 PM   #6
jrelliott
jrelliott's Avatar
When you do the continuity test of the switch and armored cable make sure the battery of the vehicle is disconnected. You can destroy an analog ohm meter by measuring voltage on the ohms scale.
jrelliott is offline   Reply With Quote
