01-10-2016, 01:12 PM | #1 |
Which flywheel to use?
Getting ready to send out a flywheel to be resurfaced for the stock 37 221. I have two and need to know if one would be better use than the other. I assume they interchangeable. The one with the raised side is what came out of the 37 and the other was included with another engine I purchased. Thanks.
01-10-2016, 01:16 PM | #2 |
Re: Which flywheel to use?
Lighter is better in most applications, is the engine stock?
01-10-2016, 01:18 PM | #3 |
I'd go with the heavy one, this will improve drivability on the street.
01-10-2016, 01:22 PM | #4 |
It is a .100 overbore but otherwise completely stock.
01-10-2016, 01:50 PM | #5 |
Might be better off with the heavy, like Ron said. With a stock engine and heavy car it can help and I'm assuming your not interested in maximum acceleration!
01-10-2016, 02:01 PM | #6 |
01-10-2016, 02:20 PM | #7 |
Thanks, I will go with the heavy one. No drag racing just a good running stock flathead.
01-10-2016, 04:56 PM | #8 |
Machine the lip off of the 9" version, that coupled with the lighter weight of the 9 " clutch will give you a better accelerating engine.
01-10-2016, 05:10 PM | #9 |
01-10-2016, 09:04 PM | #10 |
He asked if one would be better to use...
Machining the lip off the 9" flywheel will result in a lower weight package than drilling the 11" wheel to suit.
