01-04-2016, 10:08 AM | #21 |
Re: 39-40 hot water heater
01-04-2016, 10:17 AM | #22 | |
01-04-2016, 10:21 AM | #23 | |
01-04-2016, 10:29 AM | #24 |
On my 1939 Ford hot water heater but in my 1937 Ford I hooked up according to original instructions.Upper outlet which would be on passenger side returns to radiator hose. Lower outlet which is on or toward drivers side goes across front of carburetor to heater valve top of passenger side head. I think all of this is in 1939 book or an article Tom Cherry did years ago in V8 Times. Drake sells the proper heater hose clamps.
"Never complain,never explain"... Henry Ford II |
01-04-2016, 10:53 AM | #25 |
I kinda agree with jseery. I think it should work either way, but it's not.
My valve is open, I had the heater out last year and flushed it out. So cold up here temp gauge never hits 160 in winter months. I get (At best) luke warm air, nothing that will warm cabin. I'm open to suggestions.
Thanks - 30-9 1939, 1940 |
01-04-2016, 11:03 AM | #26 | |
As an aside, Tom Cherry Jr was an avid V8er and one of the nicest guys in the hobby. His son Tom III continued with the heaters for a while but was more of a muscle car guy.
Alan |
01-04-2016, 11:08 AM | #27 |
Thx but I would think trapped air would work its way out eventually
01-04-2016, 11:29 AM | #28 |
What thermostat are you using that doesn't allow the temp to get to 160? For starters I would want at least a 180 degree thermostat and if you are having problems keeping the temperature up block off part of the radiator with some cardboard. Running the engine below 160 is not good on the engine in addition to not producing hot air. The engine will not lubricate well at low temperatures and you end up with increased wear. In addition the oil will not get hot enough to burn of the impurities and you will end up with a lot of sludge build up. Need to get the operating temperature up!
01-04-2016, 11:44 AM | #29 | |
Many people have the bad habit of thinking that a 160 degree is better for their engine.. I can clearly recall the automotive class I attended in 1952 that covered automotive cooling systems. The class stressed the importance of 180 degree's being the optimum temp for an engine. At 180 the majority of the contaminates formed in the oil during the combustion process, would be burned/cooked out of the oil, thereby extending engine life. The automotive standard is now 195... I know several people that insist on running 160 thermostats in their late model engines, then they wonder why the engine runs poorly. I recently installed a '97 Chevy 5.7 Vortec engine and 4L60 AT in my '64 C10 pickup. We used the stock ECM (computer) that was reprogrammed for my application. The mechanic assisting me with the installation wanted to use a 160 stat, I insisted on a 195 because that is what the "book" called for..
Bill.... 36 5 win cpe Last edited by blucar; 01-04-2016 at 11:59 AM. Reason: added info |
01-04-2016, 11:51 AM | #30 |
Js I don't know what thermostats I have in there, bought car and never opened it up.
As always you provided me very good advise and I will try it
01-04-2016, 12:03 PM | #31 |
For now you can just block off part of the radiator to get the temperature up. It is a trial and error process to find the correct amount to block off.
01-04-2016, 12:05 PM | #32 | |
01-04-2016, 12:08 PM | #33 |
Not necessarily.
01-04-2016, 12:10 PM | #34 |
Can I purchase the 180'thermo at Napa? Anyone have part number?
01-04-2016, 12:13 PM | #35 | |
01-04-2016, 12:13 PM | #36 |
Once the engine is up to operating temperature check the temperature of each heater hose at about 3" from the firewall. They should be very close in temperature. If not, I'd be looking at getting the core flushed professionally.
01-04-2016, 12:14 PM | #37 |
Yes, but they will not fit properly and may very well "ride up" in to the radiator hoses w/o modifying.
01-04-2016, 12:16 PM | #38 |
Thanks Kube will look online - carpenters/c&g/drake
01-04-2016, 12:19 PM | #39 |
Henry has a method of using newer style thermostats with some small wires to retain them. I have not tried that method. He has posted on it several times.
http://fordbarn.com/forum/showthread...rmostat&page=2 Post #28 has a photo of what he does. |
01-04-2016, 12:42 PM | #40 |
American inginuity Pretty cool
Back to needing Napa part number
Thanks - 30-9 1939, 1940 Last edited by 30-9; 01-04-2016 at 12:53 PM. |
