Old 06-06-2015, 03:09 PM   #21
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Short in Main Harness or light switch!??
ok the rod is NOT making the correct contact into the bail...Down is off, 1 to the right is lights, 2 to the right is brights, 1 to the left is cowl if you have or parking..This is what it should do and if it is doing it another way it has to be able to do it the right way. Check the inside of the bail for the way all is put together for me.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-06-2015, 03:13 PM   #22
msmaron
msmaron's Avatar
Ok have to ask a dumb question, are you putting the bail on upside down?? Just have to ask everything to attempt to help
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-06-2015, 03:15 PM   #23
msmaron
msmaron's Avatar
light bail
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-06-2015, 03:17 PM   #24
30aadoodlebug
30aadoodlebug's Avatar
I don't know why, but I just noticed that the inside of the switch was bent. It looks like the person who had the car before me tried to remove the old harness from behind the switch without knowing that that's where the contacts were. After a few tweeks with a small pry-bar the lights and horn are up and running as they should be. Now I just need to fix the stop light switch and I'm set. Thanks for all the help Mark, I really appreciate it.
Best,
Jon
30aadoodlebug is offline   Reply With Quote
Old 06-06-2015, 03:19 PM   #25
msmaron
msmaron's Avatar
I knew something was not fitting correctly and glad we found it for you...My pleasure always. What is wrong wit the stop light switch.. call A&L parts and get a new one..They are PERFECT!! easy and done!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-06-2015, 03:22 PM   #26
30aadoodlebug
There she is all lit up!
Old 06-06-2015, 03:23 PM   #27
msmaron
msmaron's Avatar
Now that is what we want!!!! Nice going!!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-06-2015, 03:26 PM   #28
Bob C
Here are a couple of pictures that may help. The picture
of the light switch shows it in the off position, make sure your
spider is in in the same position when you put the switch on
the column.
Old 06-06-2015, 03:27 PM   #29
msmaron
msmaron's Avatar
the column.
BOB all done, we got him up and running fine, take a look at the posts!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-06-2015, 03:43 PM   #30
Mitch//pa
glad you and mark got it worked out..
i had to slave on the lawn
Old 06-06-2015, 03:50 PM   #31
Bob C
I see that, looks good. I have to learn to post faster
Bob
Old 06-06-2015, 03:50 PM   #32
msmaron
msmaron's Avatar
Originally Posted by bob c View Post
i see that, looks good. I have to learn to post faster :d
bob
hahahaha
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 06-07-2015, 08:41 AM   #33
Tom Wesenberg
Tom Wesenberg's Avatar
Your brake switch may not be bad. Does the pedal come back ebough to push the plunger to the off position. The 30-1 brake switch is spring loaded to always be ON until the brake rod pushes it to the OFF position.
The 28-9 switch is spring loaded to always be OFF until the brake pedal link pulls the switch rod to the ON position.
