06-05-2015, 05:27 PM | #1 |
Ignition cable removal.
Need to remove ignition cable from distributor body. More than hand tight!! How do I loosen without marring cable? Should cable be screwed in far enough to make indent in lower body plate area here where condenser connects? Thanks for your help..
06-05-2015, 05:35 PM | #2 |
Re: Ignition cable removal.
I have wrapped it with duct tape and used soft jaw vice grips. Probably a better way, but that's how I did it.
06-05-2015, 06:18 PM | #3 |
The indent is manufactured into the lower plate.
06-06-2015, 11:45 AM | #4 |
use some penetrant first.
bob |
06-06-2015, 04:39 PM | #5 |
It is very easy to tighten it too much and cause a short. Just hand tight is plenty.
06-06-2015, 04:50 PM | #6 |
