Old 06-06-2015, 04:48 PM   #21
Fred K-OR
Fred K-OR's Avatar
Default Re: Northwest Regional Meet
Originally Posted by Rex_A_Lott View Post
This sounds right, but its remarkable that its the same problem with two different distributors. Still possible though.
Take a real good look at the switch.
Good Luck. I've always admired the pics of your Huckster, hope you get it fixed, fast!
Rex, thanks for the comments about the huckster.
I have installed all new parts in both distributors. But the thing I did not do, on both of them, is put in the insulator washer on the point bolt that has the nut under the top plate. I notice the clip on the wire under the top plate that ties to the points, when turned will almost touch the rivets that hold the points bolt on the top plate. So I have ordered some of these washers to see if I can get this clip a little further away from those rivets. My thinking is that the nut on the points and the clip may turn just enough when the spark is moved to have that clip touch the rivets and short. Any thoughts on this or am I dreaming.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 06-06-2015, 07:27 PM   #22
LopezCarguy
LopezCarguy's Avatar
Gary; We will leave Island on 22nd and stay in motor home in town..head to Walla Walla on Tuesday..meet up with Jim and Perry in Duvall..and you if we catch up with you..nothing on docket till wine tasting that evening..time to get settled in and get re-aquainted....Dick
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
