06-03-2015, 08:31 AM | #41 |
Re: U joint housing
Is that grease or grit on the speedometer gear?
Don't forget to install the missing oil slingers when you do the tranny. They came in two sizes, so you need the correct size. |
06-03-2015, 09:17 AM | #42 |
Re: U joint housing
It's grease. It's messier than a soup sandwich.
06-03-2015, 06:23 PM | #43 |
Re: U joint housing
06-03-2015, 06:41 PM | #44 |
Re: U joint housing
Before you do the final install make sure the thrust washer is in place, it's the washer with holes in it. Look at the space between the speedo drive gear and the slot for the ring clip, if it's wide you might try two thrust washers so the gear is centered in the slot.
06-03-2015, 07:12 PM | #45 | |
Re: U joint housing
06-03-2015, 07:17 PM | #46 |
Re: U joint housing
06-03-2015, 10:34 PM | #47 | |
Re: U joint housing
Bill W.
06-05-2015, 01:11 PM | #48 |
Re: U joint housing
In the first photo with the baffle missing did the bearing stop / snap ring groove break out ? Is that what I'm seeing ? I'm close to doing the same install and have been watching this thread maybe I can do it right hopefully the first time .
Dennis in Kelsey ca |
06-05-2015, 06:47 PM | #49 |
Re: U joint housing
Yes, the snap ring and groove broke and were in the transmission.
06-05-2015, 07:18 PM | #50 |
Re: U joint housing
Thanks Art good luck with the repairs . There's not a lot of metal in that area .
06-06-2015, 10:23 AM | #51 |
Re: U joint housing
Tom good point.
