Old 04-29-2019, 06:48 PM   #1
old Tom
Default 2 blade fan
I have a 2 blade fan on my 28 sport coupe I'm gong to replace the water pump would I be better off putting a 4 blade fan on rather than the 2 blade?
Thanks
old Tom is offline   Reply With Quote
Old 04-29-2019, 06:55 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 2 blade fan
The new aluminum 2 blade is best and looks by far the most original.
Old 04-29-2019, 07:25 PM   #3
WHN
Two blade aluminum fan and leak less water pump. Enjoy,
Old 04-29-2019, 08:31 PM   #4
Synchro909
Synchro909's Avatar
Thanks
Have you been having over heating problems? If not, it aint broke so don't fix it. If yes, the fan is not the cause. Look elsewhere.
Old 04-29-2019, 09:45 PM   #5
chrs1961815
chrs1961815's Avatar
Stick with it. Mixed evidence has shown that 2 blades are mostly better than 4 blades in cooling. That and originals are somewhat safer than the aftermarket 4 blades - less rivets to come lose. If you stick with it, be sure to periodically check for cracks and looseness. But if you decide to get the nice repro 2 blade, you will have no trouble.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
