01-10-2016, 01:40 PM | #1 |
Torque tube cover gasket
Working on a 1936 ford.
Here is a pic of the torque tube cover and a cork gasket that came with a gasket set for the transmission. How do you install the gasket ? Is any type of sealer used ? Sent from my iPad using Tapatalk |
01-10-2016, 02:49 PM | #2 |
Re: Torque tube cover gasket
You may want to consider using a non-stock seal such as the one made by Hot Rod John as discussed here. Let us know what you decide.
https://www.fordbarn.com/forum/showth...clamshell+seal https://www.fordbarn.com/forum/showthread.php?t=35729&highlight=torque+tube+clams hell+sealt=140751&highlight=torque+tube+clamshell+ seal[/url] http://www.jalopyjournal.com/forum/t.../#post-5043959 and available here: http://www.ebay.com/itm/1928-48-New-...1UJ0s8&vxp=mtr Last edited by 19Fordy; 01-10-2016 at 02:56 PM. |
01-10-2016, 03:07 PM | #3 | |
I use the handle end of a screw driver to push this seal in to the channel. No sealer is really necessary. However, if it makes you more confident, place a dab of Permatex® #2 on each end where the covers will mate. Personally, I have installed dozens of this type of seal with no issues.
01-10-2016, 05:53 PM | #4 |
The other alternative is felt, which Roy Nacewicz at Fordbolts.com supplies. It's a lot easier to install and doesn't dry out (from shelf time) or break.
01-10-2016, 08:18 PM | #5 |
The chance of leaking will be most likely be from the gaskets , they are very thin. I see in your picture you have sanded it [them] flat its a good start, you may want to do a little more. Put some sticky Permatex on those gaskets and you'll be fine.
"Came too close to dying to stop living now!" |
