01-20-2020, 01:05 AM | #1 |
stromberg 97 metal fatigue?
Don't you hate when this happens?? AND I was trying to get the hose nipple OUT, not tighten it...
Plus, All of the used parts I can find for sale to replace this are almost $100!
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
01-20-2020, 03:52 AM | #2 |
Re: stromberg 97 metal fatigue?
Ouch!! looks like it's been epoxied up previously?
01-20-2020, 04:58 AM | #3 |
Yep, it sure looks like someone who thought that JB weld was the perfect solution for a broken part, put a layer of it inside to fix it. (guess that didn't pan out to be a permanent solution)
01-20-2020, 05:34 AM | #4 |
Ooyah!
I've always been a 94 guy, they seem easier to find here. Never had a 97. I hope you can find a decent used part to repair it. Mart. |
01-20-2020, 08:02 AM | #5 |
What is worse is that somebody trusted JB Weld or something similar to not only fix the prior problem, but to also NOT LEAK and potentially cause a fire.
Now this is going to sound bad, but it is actually a good thing that it snapped off - as it prevents the carb from being used "as is" . . . now it will be fixed - with a new carb center as it should have the first go round. Just put a "Want Add" in for a new center section - you might find one for less than a complete carb core. Best of luck! B&S Last edited by Bored&Stroked; 01-20-2020 at 09:36 AM. |
01-20-2020, 08:12 AM | #6 |
01-20-2020, 09:24 AM | #7 |
caj,
E mail me at [email protected] , I've got 97 bowls up the ying yang. If you wish one will be heading your way pronto. Charlie ny |
01-20-2020, 10:58 AM | #8 |
Yep. I figured it was a patch job, Thanks Charlie, email sent buddy!
01-20-2020, 01:49 PM | #9 |
That Charlie's funny, yeah? That Charlie is good, YEAH ! DD |
01-20-2020, 02:37 PM | #10 |
JB Weld is good for certain things, but that could cause your car to burn to the ground.
I've seen it work when exposed to gasoline before ethanol was added years ago. I've seen carbs using fuel with 10% ethanol, where the JB Weld starts to deteriorate. Sal Sal |
01-24-2020, 12:59 AM | #11 |
Is it bad that i figure, in a pinch, you could drill tiny holes either side & bond it slightly with solder?
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
01-24-2020, 12:16 PM | #12 | |
01-24-2020, 12:29 PM | #13 |
I have a 97 with an extra 3-16” hole drilled in the top of the bowl. Was thinking JB weld to fill it, but now I’m thinking I should tap it for a plug.
01-24-2020, 12:37 PM | #14 |
Indeed, already have a replacement tank in route thanks to Charlie!
