Old 02-16-2020, 10:08 AM   #1
sphooch
sphooch's Avatar
Default A big job ahead
I was just on this site with my Pitnam arm fix and now I have a new problem while working on the pitman arm I saw the drag link was rubbing on the tie rod. looking at the Les Andrews books I did the required measurements and as such determined the front spring should be replaced.i found on this site A-Spring made in the U.S.A. was the best. is this a big job, can some tell me if the Les Andrews replacement instructions are enough or are there some other things I should be aware of. thanks again THE HOOCH
sphooch is offline   Reply With Quote
Old 02-16-2020, 10:31 AM   #2
whirnot
whirnot's Avatar
Default Re: A big job ahead
It's not too bad, but you need to find a spring spreader you can borrow.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-16-2020, 10:39 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Ditto Whirnot! With a spring spreader, replacement of the front spring is relatively simple.
Bob Bidonde
Old 02-16-2020, 11:33 AM   #4
AL in NY
AL in NY's Avatar
I did both front and rear springs last year. You don't need a spring spreader to remove and replace the front spring. You just need a medium sized C-clamp to assemble the leaves of the front spring. Follow Les Andrews instructions and you'll have no problems. Easy one man job.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-16-2020, 11:36 AM   #5
1931 flamingo
1931 flamingo's Avatar
Like Al says.
Paul in CT The rear spring is a different story.
Old 02-16-2020, 11:38 AM   #6
WTSHNN
WTSHNN's Avatar
Agree that Travis at A Springs is the best option.
While you can do without a spring spreader I feel its safer and easier to use one. If you dont have one check with your local MARC region and see if someone has one you can borrow.
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 02-16-2020, 11:47 AM   #7
AL in NY
AL in NY's Avatar
WTSHNN: The front spring is not under much tension, a spring spreader is NOT needed.
AL in NY
Old 02-16-2020, 02:16 PM   #8
sphooch
sphooch's Avatar
thanks for the info. I do have a spring spreader and I also have a varity of c - clamps, both large and small. So I'll just follow Les Andrews . Now I just have to order the spring and get going on it. Thanks for the help once again. THE HOOCH
Old 02-16-2020, 02:28 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
I just replaced the front spring on my Town Sedan.
I got the spring from "A" Springs (http://www.a-springs.com/products.html), bushing pre-installed. I replaced the shackles and bushings in the spring perches at the same time. It took me less than an afternoon to install (after paint was dry), working by myself. I have a spring spreader but some use 2X4s.
Old 02-16-2020, 07:42 PM   #10
Sunnybrook Farm
Sunnybrook Farm's Avatar
As I remember when I knocked the shackle out of my front spring, nothing happened other than the spring dropped down on the axle. Of course the front end was not under the car. Never took one loose while under the car!
Sunnybrook Farm is offline   Reply With Quote
Old 02-16-2020, 11:09 PM   #11
CWPASADENA
CWPASADENA's Avatar
Support the front of the car with jacks stands under the frame.
With a floor jack under the center of the front axle, jack up the axle just a little to take the pressure off the shackles. Remove the shackle on one end of the spring. Remove the U bolt bottom plate and lower the front axle just a little so the spring is free from the cross member. Remove the other shackle and remove the spring.
Watch and do not bend down on the front brake rods, you may want to un-attach them at the front clevis.
Reverse the above instructions to replace the spring. You may have to place a thin block of wood on top of the axle under the eye of the spring to help with alignment when installing the last shackle.
I have used this method for a very long time with very good success. It is fast, easy and most important safe as you do not have a spring spreader.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-16-2020, 11:24 PM   #12
holdover
Front spring not a problem, do as # 11 says, the rear spring is a different animal where you need to be careful Good luck.
holdover is offline   Reply With Quote
