01-23-2017, 08:35 PM | #1 |
LED Third brake light !!
Seriously thinking of a third brake light in my rear window of my roadster, the one that Brattons sells (10 led strip light). I have some logolite LED lights coming soon and notice they are just one wire I notice the brake light from Brattons has more than one Can I run just one wire from it to the outgoing side of my brake light switch to the third brake or is their more involved. Appreciate the input..... thanks Dutie
01-23-2017, 08:48 PM | #2 |
Re: LED Third brake light !!
I used a repop tail/brake light and fastened it to the back of the trunk. The picture shows the light on the spare tire, I moved it because the wires were interfering with the spare. I just tapped into the existing tail and stop wires and ran a separate ground wire. My set-up uses regular 6 volt bulbs
01-23-2017, 09:17 PM | #3 | |
01-23-2017, 09:25 PM | #4 |
These LED strips that hook to the back window have a provision so that you can connect them to turn signals. When using them to turn the left half will flash for a left turn, the right half will flash for a right turn. If you do not have turn signals the two separate wires used for the turn indication are connected together. Information should come with the unit.
Tom Endy |
01-23-2017, 10:10 PM | #5 |
Thanks fellas for the replies, you sure know how to take the pressure off.
PS: Ive found the full instructions by the way on snyders, just a download. Thanks again. Hey John lookin forward to meeting you at Rhinebeck, hope the weather cooperates Dutie |
01-23-2017, 10:29 PM | #6 |
01-24-2017, 11:25 AM | #7 | |
01-24-2017, 11:55 AM | #8 |
I have a third brake light strip in the back window of our '31 Chrysler sedan but could not find a suitable place to install one in our '31roadster. Ended up installing Snyder LED replacement bulbs and reflectors in the standard Model A tail light housings. They are very bright, brighter than the strip lights by far and you cannot tell them from the originals. The directional signals also are bright and function well.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
02-05-2017, 05:30 PM | #9 |
Hi fellas, Finished my LED third brakelight today in the rear window. When its activated along with the two LED brakelights gives plenty of red in your face. If I combine it with my new 4 way LED signals will look like the eagle had landed. Quality stuff from Snyders, have it in just 2 days. Thanks again fellas for the replies. Dutie
02-05-2017, 05:40 PM | #10 |
Dutie,
Did you tie the Logolites into the third brake light for turn signals? I'm considering the same setup. W. Michael |
02-05-2017, 06:26 PM | #11 |
Dutie,
I did mine like 29spcoupe in post #2 with the exception of 6 volt L.E.D.'s. |
02-05-2017, 07:05 PM | #12 |
Hi w.michael, No I did not, the logolytes are completely separate. I just wanted them to work with the brake lights only. The third brake I went off my brake switch and a close bye ground. No more wondering if they see you now. Good luck Dutie
02-05-2017, 07:10 PM | #13 |
Saw a guy riding with this warning system.
02-05-2017, 07:22 PM | #14 |
02-05-2017, 07:29 PM | #15 |
02-05-2017, 09:31 PM | #16 |
I installed a LED 3rd light... Was very simple.. About an hour job.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
02-06-2017, 12:16 AM | #17 |
02-06-2017, 01:17 AM | #18 |
When I added m third brake light I also installed a Rapid Flash Brake Light Module similar to this one. It flashes ~6 times rapidly then stays solid. A real attention getter. 12v only. http://www.ebay.com/itm/Brake-Attent...item5afc761a9e
02-06-2017, 02:38 AM | #19 | |
http://www.ebay.com/itm/122281429216...%3AMEBIDX%3AIT |
02-06-2017, 09:03 AM | #20 |
Post #13 reply. Dutie, Thanks for the compliment. I took this photo a few minutes ago from across the alley.
