10-20-2013, 06:26 PM | #1 |
1937 Tudor door seals
Am I correct in assuming there is no seal along rear edge of door at B pillar ? It looks like a seal at the top from top of hinge to B pillar along top edge of body. As always thanks in advance, Zeke
Only problem with retirement is never a day off |
10-23-2013, 06:16 AM | #2 |
Re: 1937 Tudor door seals
It probably is the same 37-40 I would think. BD shows it as running along roof edge in his catalog. Is that the only place along with the hinge edge seal ? There are two rubber bumpers at the body B Pillar, is that all ? Zeke
10-23-2013, 08:41 AM | #3 |
Real men drive cars with no door seals, You are correct the top door seal runs from the upper front hinge across the top and stops at the B pillar , there is no vertical seal on the B pillar just two door bumpers. The air seal for the car door is the windlace on the interior side of the B pillar.
dickspadaro.com |
10-23-2013, 03:09 PM | #4 |
