Old 08-23-2021, 08:21 AM   #1
Steve Pritchard
Default tIGER TIMER
Can any body tell me anything about the tiger timers i just picked one up new old stock and wanted to install it on my t any good or bad experiances with them ? Thanks steve
Steve Pritchard is offline   Reply With Quote
Old 08-23-2021, 09:17 AM   #2
redmodelt
redmodelt's Avatar
Default Re: tIGER TIMER
15,000,000+ Model T's came from the factory with a roller type timer. I go back and forth between New Day and roller type. Clean the contacts, oil, install, check timing, keep lubed and clean out every so often. The only drawback, is if the front cover is not centered over the cam shaft. Changes the firing between the 4 cylinders. You can have cylinders firing early and late.
Old 08-23-2021, 09:45 AM   #3
stevests
stevests's Avatar
An "era" original Tiger timer has a maroon colored insulator ring whereas the more recent reproduction has a more orange colored ring - easy way to distinguish.
stevests is offline   Reply With Quote
Old 08-26-2021, 05:33 PM   #4
15max
Those are my preference.
50 years and counting.
15max is offline   Reply With Quote
