11-18-2023, 08:10 AM | #21 |
Re: Inconsistent spark plug firing; can't get all 4 to fire
Coils an condensers and other components of teh distributor should not know the difference between number 2 and number 134. Have you checked for something like a foouled out number two spark plug.
11-18-2023, 10:46 AM | #22 |
I have not seen it mentioned but have you checked for "Carbon Tracking" on the coil and the distributor body and rotor.
In a darken garage, start the engine and check for "leaks" on the coil and distributor. With a clear cap you can check inside the distributor body. This is mentioned in the Service Bulletins, page 368, "Most Coil Troubles Due to Neglect". |
11-18-2023, 07:26 PM | #23 |
Is there no spark at #2? or is it not firing? Have you done a compression test on #2?
11-19-2023, 08:01 AM | #24 |
The distributor housing sometimes has internal shorts or open circuits. I know you tried a different housing. But just to make sure, measure the resistance between the #2 point inside the distributor housing and the connection on the outside for the strap for #2 plug. It should measure close to zero ohms, less than one ohm. You may need to file or scratch the point inside the housing to get a good contact.
12-18-2023, 04:12 PM | #25 |
Any updates here, Todojo????
Replace the rotor with a known good one.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
