11-07-2013, 05:16 PM | #1 |
39 REgulator
Need a photo of the original position of the regulator on the firewall. 1939 Standard Coupe Thanks
11-07-2013, 05:27 PM | #2 |
Re: 39 REgulator
I believe standards and commercials ran the generator cut out and only the deluxe models had a regulator. The regulators were wounted on the drivers side top of the firewall. See the photos in my albums. The two small holes to the right of the oil breather, on the slanted portion of the firewall, are where the regulators mount.
11-07-2013, 05:34 PM | #3 |
Re: 39 REgulator
This is my 39 pickup. I went with a regulator and a 12volt generator set up. However, to be "correct" you sould run a gernerator cut out for commercial and standard. This however will show the mounting area. |
11-07-2013, 06:57 PM | #4 |
Re: 39 REgulator
My 39 2 door had a cutout on top of the generator, but i have seen a few standards with a regulator mounted like the pickup in the picture. Whether someone changed them over or not i do not know.
11-07-2013, 07:34 PM | #5 |
Re: 39 REgulator
Jim, The Ford V8 for '39 normally had a cut-out from the factory, but were fitted with a regulator and two brush generator at the dealership if the customer had ordered a radio. The position of the regulator would then be up to the installer at the dealership, so it may actually have been installed anywhere on the driver side. If you will have your car point judged, you will need a radio, and I woiuld suggest a position several inches outboard from where Seth mounted his regulator.
Alan |
11-07-2013, 11:55 PM | #6 |
MEMBER EMERITUS
Re: 39 REgulator
Later in production I think most came with a regulator. |
11-08-2013, 12:17 AM | #7 |
Re: 39 REgulator
My 39 Standard coupe has a regulator. It is a V8 60 hp car
11-08-2013, 12:35 PM | #8 | |
Re: 39 REgulator
Now as for location of the regulator, Early factory installations were on the vertical surface, and was changed to the slanted surface to combat the buzz noise in the cab. This is interesting if your car has an original wiring harness: The factory regulator installations had a wiring harness made for it, while those without regulator were specific to cut-out, requiring a separate additional harness when installed at dealerships. Check your Rouge Ford to see which harness to determine factory or dealer radio.
Alan |
11-08-2013, 12:45 PM | #9 |
Re: 39 REgulator
Ford38v8
My car has the radio delete plate. Always had a regulator and never had a radio |
11-08-2013, 12:56 PM | #10 |
Re: 39 REgulator
That confirms the most important rula about Fords: Never say never or always!
Alan |
11-08-2013, 02:58 PM | #11 |
Re: 39 REgulator
It is not true that all "standards" were equipped with a cut out unless they had a radio. The fact is that near the middle of production Ford began to equip all '39 Fords with a regulator.
11-08-2013, 05:37 PM | #12 |
Re: 39 REgulator
There should be dimples on the firewall for the regulator screws.
11-08-2013, 10:38 PM | #13 |
Re: 39 REgulator
