10-12-2018, 10:28 AM | #1 |
1939 water pumps again
Just need to know is it normal that the water pump pulley moves forward when you accelerate and back again when rpm ties down. Pumps are newly rebuilt, movenrnt is about 1/8 inch, funny thing is that the other pump does not move, both are rebuilt. The car is a 1939 Ford Deluxe 85hp.
10-12-2018, 11:05 AM | #2 |
Re: 1939 water pumps again
Doesn't sound normal to me, Mike. Sounds like the shaft might have been reinstalled incorrectly during the rebuild.
10-12-2018, 11:38 AM | #3 |
Sounds like your pumps are the bushing type which is good. You pull the pulley
forward and is springs back when you let it loose. This is from the centrifical force as the engine speeds up. This movement helps keep it clean and pushes the seal tighter against the seat. The bearing type pumps don't move. The bushings are precision reamed to one and half thousandths larger and the SS hard shafts are ground to exactly .500 The gives 3/4 of a thousandths clearance between the shaft and bushings. There is this film of oil between the shaft and bushing, the shaft runs on this oil film NEVER touch the bushings. If the fan belt is pulled up real tight wit a big bar the oil can be squeezed our up towards the generator and wear the bushings. I have seen them so tight the wore through the bushing and into the pump casting. Contrary to what people think the pumps never leaked. As shown in the pictures the man changed the pumps because the pulley was making noise when it was scraping on the pump housing. The belt adjustment picture should show an over all movement of 1" between the 2 doted lines. When a bearing pump fails it's a new pump or the tow truck, a bushing pump will usually get you home G.M.
www.fordcollector.com |
10-12-2018, 11:41 AM | #4 |
They are springloaded but i canīt figure out where enough force to push it out comes from ??
10-12-2018, 11:52 AM | #5 | |
10-12-2018, 01:05 PM | #6 |
10-12-2018, 02:02 PM | #7 |
I tried pulling the pulleys by hand and they both move forward with ease, however the left more than the right side which is maybe why it is more noticeable.
10-12-2018, 02:05 PM | #8 |
Pulley alignment between the three pulleys might be the answer.
10-12-2018, 02:46 PM | #9 | |
Everything is pretty much precise when doing the pumps except when the impeller and pulleys are pressed on. Your doing this in an arbor press and isn't easy to control. If the movement is to great the out put pressure and flow drop.1/8" is about perfect. G.M.
10-12-2018, 02:59 PM | #10 |
My 21stud with 59A type pumps has been doing that since the year dot. I have always been amused by it but judge it to be normal.
Mart. |
