06-17-2018, 03:20 PM | #1 |
Gas leaking from float bowl
I have a 97 that leaks internally from float bowl. It is not evaporating,and with the air horn off I can watch it drop. Fuel level seems correct. I have had different power valves in it,so I do not think it is pv leaking.
Could the accelerator pump check valve be the cause? It pumps ok and the carb idles fine,but has always been hard to tune. I knew it was always low on gas when the rear carb was full,but did not realize it leaked so quickly. New 97 with 1500 miles on it. I do not want to send it off to Max if I can fix it. John |
06-17-2018, 10:30 PM | #2 |
Re: Gas leaking from float bowl
Bad gasket or wrong gasket on power valve?
06-18-2018, 12:17 PM | #3 |
Here is an installation guide from the internet.
Bruce
Works good Lasts long time |
06-18-2018, 12:19 PM | #4 |
Is it leaking from the accelerator pump hole on the top of the carburetor?
06-18-2018, 04:06 PM | #5 |
Ready for a test drive tomorrow. John |
