06-29-2012, 10:36 PM | #1 |
Differential video
Should have checked this out closer when I bought it. I didn't give a lot so I'm not out a lot, just disappointed. Looks like I'm gonna need to break it down and assess the situation...
https://www.youtube.com/watch?v=gy2uY...ature=youtu.be |
06-29-2012, 10:59 PM | #2 |
Re: Differential video
The axle will move around like that without the hub and bearing on.
Bob |
06-29-2012, 11:19 PM | #3 |
The up-down movement is normal, the wheel hub bearing keeps it centered, probably the seals are worn though.
Turning the driveshaft with 2 fingers that easy could mean the adustment has moved, or the bearing could be worn some, the preload is gone. |
06-30-2012, 08:56 AM | #4 |
How important is the preload? Is what you are seeing important enough you would break down the rear end and inspect it further?
06-30-2012, 09:30 AM | #5 |
An unknown rear is a gamble, so now is the time to inspect the inside. Remove just the left axle tube and you can remove both axles and differential to see how they look.
06-30-2012, 09:38 AM | #6 |
