Old 06-25-2012, 03:03 AM   #1
pooch
pooch's Avatar
Default 28/29 and 30/31 rumble step plate placement
Does anyone have pics or point me to pics/info of early and late rumble step plate position on rear bumper and any bracketry to bolt it on?
pooch is offline   Reply With Quote
Old 06-25-2012, 12:11 PM   #2
28ACoupe
28ACoupe's Avatar
Default Re: 28/29 and 30/31 rumble step plate placement
When I did the conversion for my dad on the coupe, we just ordered the brackets from Berts. The instructions on where and how were easy to follow. One step on the bumper bracket and one on the fender.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 06-25-2012, 04:53 PM   #3
pooch
pooch's Avatar
I like to make parts if I can make them better than repops.
Just wanted some pics to copy.
Old 06-25-2012, 10:43 PM   #4
mot
Registered User
mot's Avatar
heres the most common style
i also have the cast iron one which is different
the 28-29 had a square plate and the early 28 had the rubber insert
the carriage bolt head should be black on this one
give me specifics on what you need photos of
tom
mot is offline   Reply With Quote
Old 06-26-2012, 02:31 AM   #5
pooch
pooch's Avatar
Thanks Tom, that gives me some good clues, Bert's pic was vague.
I am running twin tail lights on a 28, so may bolt the step to the large nut that holds the oval bumper clamp on, to get some clearance for people to step over light.
Old 06-26-2012, 05:26 AM   #6
Terry, NJ
Terry, NJ's Avatar
I really don't know, but they have two types, round and square. It was my understanding that the square ones go down on bumper and the round ones go on top of the fenders. Rightly or wrongly, this how I'm configuring mine. Using a plumb line and a rule, I located the hole 3/4'' behind the center of the centerline of the wheel on the fender. I haven't got the ones (square) for the bumpers yet. I also cut a gasket or pad out of an old inner tube to go underneath.
Terry
tom
Terry, NJ is online now   Reply With Quote
Old 06-26-2012, 06:56 PM   #7
mot
Registered User
mot's Avatar
this is the most common 28-29 step plate
it was used on the fender and on the lower bracket
i dont have a lower bracket ,but it mounts on the body,rather than the bumper bracket
Brattons has the square step plates and gasket ,but no bracket
Berts may have one
mine has a hole in it which is wrong ,it had in integral bolt in the bottom
there is an earlier one with Ford script on it
look at the JS pg 15-9
that section really needs some photos to show the differences
tom
Old 06-26-2012, 07:00 PM   #8
mot
Registered User
mot's Avatar
here is the earliest 28 step plate
these are very rare
this is the only one ive seen
tom
Old 06-26-2012, 07:25 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
Tom,
Is that rubber on the bottom, outside diameter, looking at the bottom photo?
Is the outside, middle, perimeter Aluminum?
Boy, I hope you understand what I'm asking...
d.j. moordigian is offline   Reply With Quote
Old 06-26-2012, 07:29 PM   #10
mot
Registered User
mot's Avatar
dudley
the rubber is both top and bottom, the aluminum is the outer band
i should have taken a photo of the one on the car
Old 06-26-2012, 07:32 PM   #11
d.j. moordigian
Thank you Tom!
Sorry about the rambling, I've never seen one...
Old 06-26-2012, 10:21 PM   #12
Steve Plucker
dudley
Well!...And you were right there to! Oh so close!
Pluck
Old 06-26-2012, 10:28 PM   #13
Bick in New Zealand
Bick in New Zealand's Avatar
Here is a picture of the three styles for 28. The bracket shown is for LHD, the RHD is a mirror image, I have one somewhere but I cannot locate it to photograph.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 06-26-2012, 11:53 PM   #14
mot
Registered User
mot's Avatar
great photo
now just add the round ones and put those photos in the new JS
Old 06-30-2012, 11:56 AM   #15
AlanD
Here's where I put them on my '30 coupe.
AlanD is offline   Reply With Quote
