04-24-2019, 09:10 AM | #1 |
Nuts! Head nuts.... Acorn? Stainless?
I have been looking for stainless steel acorn nuts to fit the head studs but all I find are fake covers that go over the original nuts.
Does anyone sell proper acorn nuts in stainless for the flatheads head studs? Or in chromed brass? I have spent some time looking with no luck..... I guess I could make them if I really wanted too.... |
04-24-2019, 09:15 AM | #2 |
Re: Nuts! Head nuts.... Acorn? Stainless?
I think Flathead Jack did. They are/were pricey!
Looks like Red's may have them: http://reds-headers.com/html/fh_parts.html http://reds-headers.com/html/external.html Last edited by JSeery; 04-24-2019 at 09:22 AM. |
04-24-2019, 09:21 AM | #3 |
industrial supply houses, like mc master carr. should have them. most likely have to do the polishing yourself
04-24-2019, 09:27 AM | #4 |
Like cas3 said, McMaster Carr. https://www.mcmaster.com/acorn-nuts
04-24-2019, 09:29 AM | #5 |
"General" commercial available SS will not withstand the torque values needed for flathead torques.....I have some 304SS 7-16-20 NF SS Acorn nuts (Maybe 40psi max torque) but have not and will not use them on a Flathead. With that said there "MAY BE" a company offering a "hardened" SS Acorn nut (like ARP) not sure BUT if so they will not be cheap and unless the seller can provide me with certs or mill test reports I would not trust them!!!!
NOTE: The above mentioned McMaster Carr items are the same as I have and IMO I would not recommend. Max torque value is 36ft/lb dry & 27ft/lb lubed. They are the standard commercial variety!!! Last edited by rockfla; 04-24-2019 at 09:38 AM. |
04-24-2019, 09:41 AM | #6 |
04-24-2019, 09:43 AM | #7 |
Looks to be just over 100US for a set.
04-24-2019, 09:48 AM | #8 |
"Could"......is another word "possibly". Its a you're gamble with you're motor. Factoring in the head cycles and the "recommended" values I'm not that big of a gambler!!! Just my .02 worth!!!
04-24-2019, 10:00 AM | #9 |
I would check with Red's and see what the torque values are for the ones they have.
04-24-2019, 10:12 AM | #10 |
Jaguar XKE head nuts work. Not Cheap. Dave Green Bay
04-24-2019, 10:39 AM | #11 |
According to the Red's page, theirs are "Chrome plated" which would indicate to me that they are a steel nut that is chrome plated?????, I see no mention of SS. I'm with JSeery, I would see what Red's charges for theirs IMO???
04-24-2019, 01:44 PM | #12 |
Save yourself tons of money and aggrivation.
Go with acorn nut covers like in the old days. |
04-24-2019, 03:20 PM | #13 |
Fastenall
04-25-2019, 12:17 AM | #14 |
I'm with 19Fordy, go with the chrome plated covers and save yourself $$ and grief!! Torquing the heads is somewhat important....think I read this somewhere!
04-25-2019, 12:23 AM | #15 |
No fake nut covers for me. That just seems wrong.
04-25-2019, 07:33 AM | #16 |
They're real nut covers. 8^) Jack E/NJ
04-25-2019, 07:41 AM | #17 |
04-25-2019, 07:44 AM | #18 |
Not to mention having the proper threads. Oops, I mentioned it!
04-25-2019, 09:34 AM | #19 |
I'm running covers on my 8ba that I got from Patrick's (before he went sideways). Used a bit of silicon to make sure they stayed on. No issues and IMO they don't look like covers.
Making the simple complicated for over 30 years. |
04-27-2019, 07:32 AM | #20 |
My local hardware store carries the covers, a dab of silicone and they have been on for 3 years with no problems.
