Old 07-15-2018, 10:54 AM   #1
Gabalus
Default Model BF Ford carb (1932-34)
Hello,
Someone knows the characteristics of the carburetor mounted on the 1932 british model BF Ford (Float, etc ...)? This is a Zenith Ford 33 vem.
I tried other carbs (model A, model AF and model B Ford carb ) but the engine didn't run fine.
Thank you.
Gabalus is offline   Reply With Quote
Old 07-19-2018, 04:35 AM   #2
Gabalus
Default Re: Model BF Ford carb (1932-34)
Any advice ?
Or put a model B Ford carburetor with a smaller id venturi ?
Old 07-19-2018, 12:03 PM   #3
ursus
Zenith made a range of venturi sizes to fit the Model-B type carburetor: 17, 19, 20, 22, 24, and 26mm. Maybe try a narrower one, if you can find it?
Old 07-20-2018, 01:24 AM   #4
updraught
updraught's Avatar
You can put two of these carbs on one engine, dual updraught, and I gather it runs fine. That's one carb for two cylinders.
What does "didn't run fine" mean?
updraught is offline   Reply With Quote
Old 07-20-2018, 05:19 AM   #5
juke joint johnny
juke joint johnny's Avatar
Gabalus
Contact John Charlton on here,
He knows a lot about the pot metal carbs fitted to the BF engine
The Zenith vem pot metal carb is totally different than the cast iron one fitted in the USA
John Cochran
juke joint johnny is offline   Reply With Quote
Old 07-20-2018, 06:50 AM   #6
johnbuckley
johnbuckley's Avatar
Can you post a pic, many Model Bs ended up with non standard carbs over the years. I have info/data on some of them. Is it the alloy 33 VEM- 2 you're after? I have details of the jetting for the 24 hp version of this model and from those figures one can deduce the correct sizes to suit the smaller bore engine..Maybe best to email me personal message rathe than clogging up Fordbarn with pages of data!
Old 07-29-2018, 06:24 AM   #7
john charlton
john charlton's Avatar
As John says, the potmetal VEM 2 carb is totally different from the iron Model B carb. So the jets are not interchangeable.
For the small bore BF engine I think that the VEM carb has a smaller venturi cast into it so not interchangeable with 24hp. I do not have a BF VEM 2 carb body with the smaller venturi. I have a 1928 AF Phaeton with the small bore 14.9 engine. It would not run well on an original AF carb, with correct jets and small venturi, so I fitted a regular 24hp Tillotson bolted up to the small bore 14.9hp inlet manifold. It runs like a champ even though there is not a matching bore size between carb and manifold.
Check that you have got the correct small bore inlet manifold. If you have the 24hp manifold it will never run well, no matter what carb you try. Your inlet manifold bore should be 1"
Best regards
John in stormy changeable sunny Suffolk UK
