Old 06-10-2017, 11:34 PM   #1
Dtolson9
Default Oil leak
I ran my car last Sunday parked it then came home on Wednesday to this mess in my driveway. Any ideas before I start?
Dtolson9 is offline   Reply With Quote
Old 06-10-2017, 11:41 PM   #2
RawhideKid
Default Re: Oil leak
Put a pan under it?
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 06-11-2017, 01:58 AM   #3
Synchro909
Synchro909's Avatar
What part of the car was directly above the mess? Most likely, the back of the engine. If so, start with the rear main bearing. Check for clearance, end play in the crank, oil return pipe, slinger, the rear end of the cam shaft etc. Do a search - there will be plenty of info already here.
Old 06-11-2017, 02:02 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Do a search of the site for a rear bearing leak.
In addition to the search here, here is a site that has some info.
http://antiqueenginerebuilding.com/REARMAINLEAK.html
Old 06-11-2017, 04:25 AM   #5
Dollar Bill
Dollar Bill's Avatar
Hard to judge from photo but is car parked on an incline with the rear lower than front?
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 06-11-2017, 06:24 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
On the bright side, you are lucky it was on concrete and not tar, like my driveway has.
Old 06-11-2017, 06:47 AM   #7
Patrick L.
Patrick L.'s Avatar
Also, how hard were you driving just before this.
Old 06-11-2017, 08:29 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Did you happen to JAM the oil cap down too TIGHT???
Bill Ididitonce
"THE ASSISTANT GURU OF STUFF"
Old 06-11-2017, 08:37 AM   #9
Railcarmover
thats a good sign,it means it still has oil in it..
Railcarmover is offline   Reply With Quote
Old 06-11-2017, 08:41 AM   #10
Big hammer
That looks like crude oil! Maybe transmission leak?
get a bigger hammer tap done
Old 06-11-2017, 09:06 AM   #11
Don S.
Don S.'s Avatar
First thing I would do is to try to clean as much oil off as you can. Maybe a can of gunk cleaner and spray it off with a garden hose. Take it for a short ride and park it. Cardboard underneath gives you a clean surface to try to identify the leak area. I had a very similar issue on my coupe. Drove it, parked it, and came out to find large puddles. I was ready to pull the oil pan and go at the rear main. Turns out it was the side valve cover gasket. It must have "cooked" right behind the exhaust at the rear of the motor. The oil ran down the very back of the engine block and dripped off the end, just like a rear main leak. Good luck to you!!
Don S. is offline   Reply With Quote
Old 06-11-2017, 09:14 AM   #12
Gunmetal blue2
Gunmetal blue2's Avatar
when you get the oil off the cement as good as you can, put white vinegar on oil spot. this will help clean the oil stain.
Gunmetal blue2 is offline   Reply With Quote
Old 06-11-2017, 09:51 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
How full is the crankcase---was it just topped off before the drive---is the level up to the "F" or covering it, the model a engine is very good at eliminating excess oil
Kurt in NJ is online now   Reply With Quote
