02-20-2012, 05:40 PM | #1 |
How Can I Tell If It's a 'Special Coupe'???
Greetings, all. I'm about at my wit's end with this car of mine. It appears that a previous owner replaced the top at some point. Unfortunately, it also appears that Ray Charles was called upon to perform the replacement...
Before I rip the top off, I wanted to gather the necessary parts to make it the process go smoother. As I'm looking closer at it, I can't tell if the car came from the factory as a Special Coupe, and not a Standard Coupe. Are there good methods to determine how this came from the factory? My experience has been later model vehicles (muscle car era), which now seem MUCH easier to research. Any tips? Thank you in advance!! |
02-20-2012, 06:04 PM | #2 |
Re: How Can I Tell If It's a 'Special Coupe'???
It sure looks like one to me & I have one.. Does it have a belt rail around the lower back ?? And another thin one over the top just above the rear 1/4 window.. And smaller strips around the rear windows.. If so thats it.. They never came from the factory with cowl lights..
02-20-2012, 06:15 PM | #3 |
The Special Coupes were made for about one year starting July 10th 1928. They do have the special moldings that Fred mentioned and some additional wood in the body to support some of those moldings. If you don't have the belt rail and moldings behind the quarter window, they can be very difficult to locate.
Dave |
02-20-2012, 06:19 PM | #4 |
Fred, yes, it does have the belt rail. The thin one over the top is there, but looks like it's glued on (I can see no nails/screws, except at the end), and there are little ones around the quarter windows. These all appear, however, to be aftermarket. The drip rails are aluminum, and not very pleasant to look at. I have seen a couple of pictures of Special Coupes with the tops removed, or in the process of having them replaced, and there doesn't appear to be any metal between the rear window and the quarter windows. Is this accurate? I took an old speaker magnet and felt metal in between the windows, which leads me to believe that this might have been converted to a Special, but still might be a Standard underneath.
Thoughts? |
02-20-2012, 06:42 PM | #5 | |
http://www.abarnyard.com/ |
02-20-2012, 06:48 PM | #6 |
Even your Special coupe will have metal nailed to the wood frame, then padded and covered. If the headliner is out of the car, you should see the metal panels. Sport Coupes (permanent cloth tops with landeau irons) and Business Coupes (cloth again, no landeau irons, with or without oval sidewindows) were also offered in these years. The Deluxe Coupe was a different designation for a 30-31 Coupe with the extras... cowl lights, dome light, etc. and is not a "Special Coupe". Clear as mud? I would say you have a Special Coupe without the original metal belt at the body line. Have fun with it. |
02-20-2012, 07:07 PM | #7 |
It sounds like the pictures you have seen were SPORT Coupes being done,not Specials.Specials do have metal all around. I prefer 30-31 cars myself,but the Special Coupe is one of the best looking A's made as far as I'm concerned.
02-20-2012, 07:23 PM | #8 |
Absolutely clear as mud!! Thank you all for the responses. My initial plans may have changed, then. I had planned to use an insert ala Standard Coupe, and if the Special parts coming off are hammered, I may save them for another time, unless I can find a killer upholstery guy to make the top look better than the substandard attempt on it now.
02-20-2012, 07:26 PM | #9 |
Actually, I have one more clarifying question - would it be possible to install a Standard top insert on this body, if replacement parts became unavailable?
02-20-2012, 07:33 PM | #10 |
I wouldn't even attempt to make the change you refer to. Besides, you have something to keep, as it is "Special". If you want a standard coupe, they are not that hard to find. better yet, replace this top yourself. kits are available.
I can tell from the number of posts, you are new to this. Your best bet is to meet other A people in your area, and they will be more than willing to help you. Sounds like you need a mentor... |
02-20-2012, 07:45 PM | #11 | |
02-20-2012, 08:10 PM | #12 |
The new Bratton's Catalog has a top kit for the Special Coupe for $199.50. If I were closere to you, I would offer my help. You can do it. I think You Tube has videos on top replacement. If you don't have the proper trim piece, Hidum Welt will work. You can do it. And the satisfaction that comes with it is well worth it. Did I say, "You can do it"?
02-20-2012, 09:14 PM | #13 |
You can't be to far from Berts in Denver.
02-20-2012, 11:26 PM | #14 |
You would need to purchase (and restore) the entire upper body section from a 45-A coupe from the belt line up and replace the same from yours to do so.
02-21-2012, 04:10 PM | #15 |
Got it, thank you all!! I think it's clear that I will retain the Special top, and look for a top kit for my summer project.
I appreciate it, guys! |
02-21-2012, 04:27 PM | #16 | |
02-21-2012, 05:38 PM | #17 |
02-21-2012, 09:27 PM | #18 |
Be very careful with that belt rail. If you damage it, you will look long and hard to find a replacement.
02-22-2012, 09:28 AM | #19 |
RcT, That top does need help. I noticed the two "Darts" in the corners where the roof rolls down. The first kit I bought came with these, but it belongs on another car (Blind Back?) I sent the kit back and waited for the right one and when it came I was pretty nervous of tackling the job. But I am here to tell you it can be done with time and patience. Oh, and Pick a warm day or a hot garage. If you click on my name you should be able to view my album which has some detail of the roof structure. Glad someone else is preserving another "special" coupe. Rusry has one too as well as a few other posters. Welcome to the best site in the world!
02-22-2012, 10:26 AM | #20 |
Brattons, sells upholstery kits made by Cartouche. I bought my initial top from them and it had the wrong material and they had put extra seams at the top corners of the rear panel. I had talked to Cartouche before ordering the kit and I thought they knew what I wanted. It was sent back, and I ordered the second top from Classtique and that is what is on my Special Coupe now.
Dave |
