Old 07-08-2016, 12:49 PM   #1
rnch
Thumbs up "Blow By" MUCH less! Rings were stickly?
A few guys here may recall my thread asking about excessive blow by from my low mileage '65 352 engine.
After a fresh oil & filter change, with a quart of Risoline added, 300 miles later, the hot engine in drive blow by is greatly reduced. Down to about what I thought it should look like.
I guess the mostly interstate driving and Risoline helped the rings to unstick?
rnch is offline   Reply With Quote
Old 07-08-2016, 01:34 PM   #2
Ole Don
Ole Don's Avatar
Default Re: "Blow By" MUCH less! Rings were stickly?
Yes, Rislone and CD2 are similar products. They free up rings and valves and hydraulic lifters. I had a 283 Chev come to the station where I worked at the time, lifters rattling like crazy. I poured in a can of CD2, by the time the can was empty the noise had begun to clear up. After the lady paid, I went back out and the car was quiet.
Ole Don is offline   Reply With Quote
Old 07-08-2016, 02:12 PM   #3
wbedwards
wbedwards's Avatar
You really want to blow your dress up, drive it about 1000 miles and change the filter. Then cut the old one open and look in the bottom in the pleats.
http://i791.photobucket.com/albums/y...ps8ofo3r6b.jpg
http://i791.photobucket.com/albums/y...psgygb4qwh.jpg
wbedwards is offline   Reply With Quote
Old 07-08-2016, 02:29 PM   #4
rnch
Thumbs up Re: "Blow By" MUCH less! Rings were stickly?
I plan on several more frequent than needed oil & filter changes.
Old 07-09-2016, 06:18 AM   #5
bobss396
bobss396's Avatar
Alemite made a couple of oil additives, I recall the CD2 that was as thick as honey. I know they had one to un-sticky things. The trick if not to over medicate an engine, try one thing and give it a while.
bobss396 is offline   Reply With Quote
Old 07-09-2016, 07:40 PM   #6
JeffB2
JeffB2's Avatar
300ppm more ZDDP than the newer Rotella and higher detergent,good Ford Stuff too
http://www.walmart.com/ip/Motorcraft...0-5qt/16940218
JeffB2 is offline   Reply With Quote
Old 07-13-2016, 04:17 PM   #7
willowbilly3
I had a customer with a 440 Chrysler wagon come in with a lifter whacking pretty bad. Started pouring in Risolene and half a can in it went quiet and never flared up again.
willowbilly3 is offline   Reply With Quote
