Old 07-25-2013, 03:56 PM   #1
duffer
duffer's Avatar
Default brake adj. board
Wouldn't it be better to make the brake adjustment board out of aluminum instead of wood? (The board you use to put on the brake pedal)
duffer is offline   Reply With Quote
Old 07-25-2013, 04:46 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: brake adj. board
I, personally, never use the board. I adjust all rods equally & it also results in a higher brake pedal. Also, I don't EVER want my rear brakes to apply FIRST, especially on wet pavement. Do we ever hear of modern cars that apply the rear brakes before the front ones? Yes, some will disagree, but I've found, that for me, the above works best.
I "dumped" a car over once, when the rears only, skidded in the rain! (EEK!!) Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-25-2013, 04:50 PM   #3
marc hildebrant
marc hildebrant's Avatar
The question was about the use of aluminum vs wood....not the old brake brew-ha-ha.
I use wood because it was real easy to make with hand tools. Metal would last longer, but the tool doesn't get much use.
Marc
marc hildebrant is offline   Reply With Quote
Old 07-25-2013, 05:04 PM   #4
BILL WILLIAMSON
Marc
Well then, Marc, IF IF IF IF I ever made one, I got old boards & did you see the PRICES of ALUJIMUM??? Bill W.
Old 07-25-2013, 05:44 PM   #5
CarlG
CarlG's Avatar
I got one of these from one of the vendors. Looks like a re-made caulking gun. BTW -good idea, but - it just doesn't work!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-25-2013, 06:05 PM   #6
QGolden
QGolden's Avatar
Yup, Aluminum would last longer, but wood is easier to work with, costs less, and more accessible to most folks.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 07-25-2013, 06:23 PM   #7
SeaSlugs
SeaSlugs's Avatar
They make one to adjust brakes without a seat installed right? (meaning bare frame - no cab nothin)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-25-2013, 06:27 PM   #8
[email protected]
modela@aol.com's Avatar
Use some vice grips and clamp them onto the pedal arm at the point by the floor board when the pedal is depressed to where you want it. Draft a volunteer to step on the brake pedal and do your adjustments. Move the vice grips up the pedal arm and repeat the adjustment process. No making of anything at no cost....
modela@aol.com is offline   Reply With Quote
Old 07-25-2013, 06:55 PM   #9
SeaSlugs
SeaSlugs's Avatar
Friends who work for beer - got it
