01-06-2011, 07:00 PM | #1 |
Question 1924 frames
Question 1924 Frames - Does anyone know if the 1924 Model T truck frame is the same as the sedan Frame. I have an opportunity to purchase a panel delivery body and I need to know if it will fit on my coupe frame. thanks for any help on this. Also is the coupe and the sedan frame the same ? confused
01-06-2011, 07:21 PM | #2 |
Re: Question 1924 frames
If your panel delivery body was built for a TT frame ,it will not fit. All car frames were essentially the same from 1914-25 and then 26-27 are the same. HTH.
01-09-2011, 04:20 PM | #3 |
The front axle was the same as the car with the exception on an extra leaf or two in the springs. Everything to the rear of the firewall is different. |
