03-17-2011, 02:14 AM | #1 |
restoring front emblem
I know many of you send it out to the pro. with a delicate touch .
I'd just like to know if you do take on this task , is wax an obvious to fill in the trough before enamel , is it wise to prime this piece and how much clear for depth to the finish . |
03-17-2011, 03:18 AM | #2 |
Re: restoring front emblem
NONE of the above. The enamel isn't an enamel paint. but more like a powdered colored glass that melts and flows together at a very high temp.
When I was in 9th grade shop class we had to make fishing lures by hammering a piece of copper into a spoon shape, then apply some kind of glue and enamel in 3 or 4 colors, then stick it into a kiln to flow out the enamel. I thought it was an easy job and would like to do some more of it, but don't know where to buy the supplies. I need to repair the gas tank badges on my BMW motorcycles. |
03-17-2011, 08:58 AM | #3 |
Years and years ago my mother had a friend who made jewelery and enameled like the emblems. You mught try to find a person locally who makes jewelery as a hobby or business. Sometimes I've seen these people at craft fairs, some swap meets, etc.
Worth a shot. Paul in CT |
03-17-2011, 09:12 AM | #4 |
There was a posting pertaining to the subject sometime back. I believe the process is called "Cloisonne" and as the proceedure Tom mentions is correct.
03-17-2011, 09:24 AM | #5 |
03-17-2011, 10:15 AM | #6 | |
Without a doubt the best, Just got 2 back and amazing, NOT Cheap but if you are doing fine point the only way to go,, Well worth and a very nice person,
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
03-17-2011, 10:22 AM | #7 |
Yes! She does outstanding work.
12-01-2014, 12:35 PM | #8 |
03-17-2011, 11:57 AM | #9 |
Chuck Conway in MA also refinishes the blue style emblems. I had 2 or 3 redone and they look very good to me. They don't have the dull nickel finish, but still look very good. I think the nickel will dull over time. He only charges about $50 to $55 each to do each emblem if you have the emblem to restore. I sent him a couple pretty rough emblems with chunks of blue material missing and they looked very good when I got them back. I believe Karla, who does an excellent job I have heard, but charge much more - time and material at about $200 to $250 per emblem. If it is a fine points car to be judged, Karla probably the one to use.
Rusty Nelson |
03-17-2011, 08:43 PM | #10 |
Thanks for the like to Karla's site, nice to know that there is someone still restoring these items.
03-18-2011, 01:38 PM | #11 |
Nice to know they are doing a professional job.
I'l take my time looking into this a bit further . thanks for the responses . money's tight but i'm still pushing forward with it . |
03-19-2011, 09:28 AM | #12 |
I repaired a radiator emblem for use on my speedster. Not a professional job but it looks nice for a driver. Some of the blue enamel was broken and missing. I went to the craft store and bought an art pencil to match the blue. I ground the colored "lead" into a fine powder and mixed it with clear epoxy. I used the colored epoxy to fill the defect. After curing I sanded and polished it back to a shiny finish. The plating was gone so the Ford script and border show bare copper. I sprayed on a coat of clear and left it at that. Again, not a professional job or completely authentic but it doesn't look bad.
