06-01-2019, 04:35 PM | #1 |
Balanced Carb
Does a balanced carb offer any significant benefit over a standard unit ? Are the benefits too insignificant to notice ? Do high-flow air filters preclude the need for a balanced carb ?
06-01-2019, 05:42 PM | #2 |
Re: Balanced Carb
Guten Abend,I did a lot of research and tried to do that. I first mounted a large K & B air filter. Then I mounted a tube to equalize the pressure of the float chamber to about area choke-flap.
Now the car runs well, but needs 20 liters / 100 kilometers (4 gal / 65 miles?) If I now remove the air filter, I notice no difference. My conclusion: When installing a large-volume air filter with little flow resistance, air-ballancing is not absolutely necessary.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
06-01-2019, 09:13 PM | #3 |
Re: Balanced Carb
An air filter fitted to a Model A carby might restrict the air flow and reduce the pressure from there on right into the manifold. Because the float bowl is originally vented to the atmosphere, the pressure in there does not change when the filter is fitted. That leaves the pressure in the bowl higher than in the throat of the carby. That means more fuel is pushed through and the motor runs rich. By pressure balancing the carby, the pressure in the bowl is made the same as in the throat so no extra fuel is supplied.
If you have a balanced carby you should notice no difference compared to the original if you run with or without an air filter. The only time there is a problem is if you run a restrctive air cleaner without balancing the carby. An air filter with little restriction causes little difference. Hope I explained that clearly enough!
06-02-2019, 07:09 AM | #4 |
Re: Balanced Carb
Go check out the info from David Renner. Worth a look, Chap
http://rennerscorner.com/index.html |
06-02-2019, 10:57 AM | #5 | |
Re: Balanced Carb
Benefit over a standard unit?: If you install an air filter and IF there is any restriction, it automatically compensates for the restriction. It's automatic at all throttle positions, all speeds. Benefits too insignificant to notice?: On some cars, yes; on others, no. It really depends on how good the JETS are calibrated in the carb to begin with, and your skill at adjusting the GAV to compensate for the air filter if you do NOT use a balanced carb. Many carbs have jets that are too large to begin with. Those cars run with the GAV fully closed and are still too rich. So add the air filter restriction and they are still too rich and you do not notice the difference. You can't adjust the GAV leaner to compensate for the air filter, because you already have the GAV closed. This is what it sounds like Werner's Model A has. 20 liter/km is only 11.7 miles/gallon -- not good . These cars can do much better than that, if the carb is right. I regularly get 17-20 MPG with a balanced carb and an air filter. Does high-flow air filter preclude the need? Technically, no. All air filters add some restriction. In practice, possibly. Do you care if the engine runs a bit richer than it needs to be? Gets slightly poorer gas mileage? If not, then don't worry about it. Install the air filter, adjust the GAV down a bit, and go! Hope this helps! .
06-02-2019, 11:39 AM | #6 | |
Re: Balanced Carb
Werner indicated he is getting 16.25 mpg? (65/4) altho his numbers don't exactly jive? Last edited by Y-Blockhead; 06-02-2019 at 12:00 PM. |
06-02-2019, 02:23 PM | #7 |
Re: Balanced Carb
double.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 06-02-2019 at 05:41 PM. |
06-02-2019, 02:24 PM | #8 |
Re: Balanced Carb
Correction fuel consumtion: per 100 ml is 7 1/2 und 6 1/4 gal.
Hallo, the consumption at 100 miles in city traffic is 4.75 and long-distance overland 4.15. Note: the fuel bill takes into account that the speedometer / mileage meter records 5% too much. The main nozzles to buy are probably all too big. I have reamers to adjust the caliber. But I do not know, if I solder the original hole, how deep the pinch hole must be, in order to get the smaller flow with the smaller caliber. This only works if I measure the flow rate of the original nozzle against the manipulated nozzle. I can not do that right yet.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 06-03-2019 at 02:07 PM. |
06-02-2019, 03:12 PM | #9 |
Re: Balanced Carb
Once soldered, they must be flow tested, for that exact reason. You don’t know how long the new restriction is?
06-02-2019, 07:54 PM | #10 |
Re: Balanced Carb
it is probably better to have a professional flow your jets if you don't have the proper equipment to test them. Renner's Corner has a good reputation and is not too costly. They air balance carbs also.
06-03-2019, 06:59 AM | #11 |
Re: Balanced Carb
Guten Tag,
yes, the problem is the depth of the calibrated bore, which unfortunately is unknown. I asked Renner's if he has smaller main jets in stock. I wonder if I will build perhaps the replica of the flow rate device like Mr. Pargeter.
06-03-2019, 09:15 AM | #12 | |
Re: Balanced Carb
Or you can build the flow test apparatus. A lot of work for one set of jets. Worth the time if you think you may test a larger number of jets (for yourself or others). You also need a good sealing float needle valve on the carb to get good fuel economy, and all of the jets and the drain plug on the carb must seal tightly. You need to have a "dry carb" on the outside, no drips, weeping, etc., when the car sits.
06-03-2019, 02:32 PM | #13 |
Re: Balanced Carb
Hallo zusammen.
Correction fuel consumtion: per 100 ml is 7 7/8 in the city und 6 5/8 gal. longway overland! Joe, thanks for your big effort! I have a new 'Viton' needle float valve mounted. No drops if gas valve was forgoten. The carburetor is completely sealed, no sweat. But the GAV seat was rusty. I rubbed it with a cross-head screwdriver. But now I do it better once more with a new needle, which I loop with valve grinding paste into the seat. No, I'm the only one around here who has an A and DRIVE it. (No living room-parking car!) So you convinced me and therefore I buy a complete set of jets from Mr. Renner. I drive fuel without ethanol, so the jets have to be a bit smaller. Thanks for the advice that I will heed.
06-02-2019, 10:46 PM | #14 |
Re: Balanced Carb
I have an original AirMaze. It collects a lot of dust and dirt. I adjust the GAV 1/4 turn in and then the car runs unchanged, no noticable decrease in gas mileage. Every time I clean the filter an re oil it, think about what would've been in the engine. Im sure some still gets through though. Ive thought about buying the paper cartridge for it but haven't yet. If I do use paper I'd want to turn the element up so wouldnt be a fire hazard.
