07-21-2018, 01:21 PM | #1 |
1932 steering box o/h
Any tips for installing the lower bearing race in the box ?
Having a difficult time getting it to seat fully in the recess. Tried heating surrounding area and cooling race as well as drawing it in with thick washers and a bolt, no luck. |
07-21-2018, 04:38 PM | #2 |
Re: 1932 steering box o/h
It sounds like you have a to large cup compare it with your old one , looking through the bottom hole sometimes it looks like its not seated but it is as there's a ridge in there I have used a brass drift ,Ted
07-21-2018, 04:49 PM | #3 |
identical size races Ted, that was one of the first things I checked.
07-21-2018, 05:06 PM | #4 |
It should go in then !A press is best but try n put it on a solid surface such as a concrete floor and drift it in evenly .If you haven't got a brass drift A 3/4 mild steel rod may be soft ? enough to not damage the hardened seat
07-21-2018, 06:31 PM | #5 |
Delete.sorry
07-22-2018, 11:06 AM | #6 |
07-22-2018, 02:11 PM | #7 |
Check the Dennis Lacy thread over on the HAMB. He shows the proper sequence for rebuilding a 32 box from start to finish.
07-22-2018, 02:37 PM | #8 |
Thanks Kry and spent some time looking for that specific part of the thread with no luck.
07-22-2018, 03:14 PM | #9 |
Try this:
https://www.jalopyjournal.com/forum/...-11-16.970252/ I scanned through and found steering box stuff starting on page 10. There do seem to be some lost images though, which is a shame. I had forgotten what a well documented thread it was for anyone building a traditional modified Early Ford. Mart. Last edited by Mart; 07-22-2018 at 04:47 PM. |
07-22-2018, 03:21 PM | #10 |
duplicate of above
08-20-2018, 06:38 PM | #11 |
Thanks and figured out my issue but need the info as well.
